Howdy,
I’m looking for the Boyco running board mounting hardware for three cans of the same standard size !!!
WTB Boyco set running board mounting setup
Topic author - Posts: 475
- First Name: Joe
- Last Name: Kowalczyk
Regards,
- First Name: David
- Last Name: Schwab
Re: WTB Boyco set running board mounting setup
Just saw today at Hershey,,,,, at a Rolls Royce booth, 3 Boyco cans, no mounting bracket, $1,000.00. 3 no name cans with the mounting bracket $1,500.00. Let me know if you want me to pick them up for you!!!
- First Name: Adam
- Last Name: Doleshal
There are different widths of these. You will likely want to get the ones that fit properly on the T running board. The wider ones fit poorly and look odd on a T.
- First Name: Jeffrey
- Last Name: Hausey
You want this style. I " believe" it was called the Boyco Junior set.
- First Name: Joe
Jeffrey, yes, that’s the one
Regards,
Joe, you might make an offer for Jeffery's set. His just sit inside, unused, on some bookshelves by the looks of the photograph!
Allan from down under
- First Name: Adam
…and… You DO NOT WANT any reproduction cans if you actually intend to use them. They leak. Evidently the reproductions had some kind of “fine print” disclosure in their advertising or packaging that said they are not intended for actual use…
