Helicoil hard to reach block hole?
muzzjb
Topic author - Posts: 5
- First Name: Murray
- Last Name: Bodor
- Board Member Since: 2025
Well I finally got to installing my new copper head gasket and my new (to me) head...and of course one of the head bolts stripped in the block.
I had cleaned out all the holes and ran a tap through them to clean up the threads beforehand. I also checked that the new bolts were not too long for the holes. Many of the holes had already been helicoiled by the previous owner, with the exception of 4 that looked ok.
The bolt stripped at 20 ft lbs. It's the very last bolt on the back right of the head...not easy to get even the torque wrench in there.
Any tips on how I would helicoil that hole? There's no way to get a drill in there. If I could turn the drill bit by hand it might be accessible. I really hope I don't have to pull the whole block.
MB
MB
walber
- First Name: Walt
- Last Name: Berdan
Re: Helicoil hard to reach block hole?
I doubt there are any nice easy answers. You could probably get away with removing the radiator, and disconnect enough to pull the engine forward in the frame. Pretty much the same as pulling it completely but at least it's still resting in the frame while you work rather than messing with a cherry picker and engine stand.
Kevin Pharis
- Last Name: Pharis
If a brass car, pulling the firewall might provide the needed access…?
You might be able to drill it by using a right angle drive attachment and a short bit on a hand held drill.
15 as listed in your profile?Kevin Pharis wrote: ↑Wed Oct 15, 2025 8:30 pmIf a brass car, pulling the firewall might provide the needed access…?
Pull the hood former/firewall. Short drill bit & drill. Drill angle drive maybe.
A good point to remember you don’t have to really pull down on the head bolts. Sometime we forget to get them good and tight and that’s enough. The key to getting the head to get a good seal is to stick with starting in the middle first and going out evenly from there. You don’t need a cheater bar to tighten them up.
RGould1910
- Last Name: Gould
I'm concerned that anything short of moving engine forward would make it difficult to get a perpendicular hole drilled and tapped..Don't rely on the existing hole to align things. I've seen more than one block helicoiled without using an alignment block where the headblolts won't pass thru the head into misaligned helicoils.
It's worth the extra time.
Very important to get this right the first time, because if it is crooked it could ruin the block. Slide the engine forward and or remove the firewall. You need to get the hole straight and centered. Also deep enough to get the bolt down but not into the water jacket which could cause the bolt to rust in place. A good way to do this would be to place the head on the block without a gasket and use it as a guide to drill the hole. You will need a drill bit long enough to go through the head and into the block. Then tap the new hole to place the helicoil. All the bolts should be he length which will go all the way down with the head in place without the gasket. Then they will be able to compress the gasket. If the bolts bottom out before the gasket is compressed, you will have water and compression leaks This can either get water in the cylinders or leak out. So do it right the first time because you might not have a second chance.
You'd need an accurate drill guide, no matter how you do it.
- Last Name: Hatch
Here is a link to a Stevens tool I reproduced years ago for this job. Works great.
But now I use the Lock n Stitch Full torque insert system. It has a line up jig that works great and the inserts hold to +90 ftlbs.
https://www.mtfca.com/discus/messages/5 ... 1425415180
I only made a few of the Stevens tools. Dan
Used the cyl head as guide as the drill size fits the bolt hole. Just measure very closely to be sure the long drill won’t cut into the water jackets.
Drill straight carefully with depth indicator on the drill bit. In this fix, measured depth of block hole to compare to conical tip of the drill bit to have assurance.
The HeliCoil made for me a very good fix to the old poor threads in the block.
muzzjb
- Last Name: Bodor
Thanks to everyone for all the tips, I really appreciate it.
I'll try and remove the hood former and firewall and see how much room I have to work.
MB
MB
- First Name: craig
- Last Name: leach
Hi Murry,
Using a drill extension may get you up high enough to clear the firewall. I keep old junk heads just for this. if the insert drill is larger that the
hole in the head then drill it out & use it for a guide to drill the block. use plenty of bolts the hold the head secure & aligned. Cut the center
of the drill so it will not go deeper than the factory hole. Drill the old head to the O. D. of the tap & reinstall the head using it for a tap guide
remove the drill & tap regularly & blow out the chips. Use a bottom tap to cut the threads full depth. Remove the head & install the insert &
make sure it is not proud in the head, if it is very carefully grind it flush. In a earlier post I showed using fast food drink cup lids installed upside
down to keep dirt & chips out of the cylinders.
Dodge
- First Name: Dodge
- Last Name: Riedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Also don't use a tap to clean out head bolt threads. Use a thread chaser. The tap will remove material and weaken the threads in the block.
The taps in most commen tap sets remove too much material. They make for a loose fit. Its done that way to give a little wiggle room if you dont get the tap perfectly lined up. There are up to 5 grades of taps each one going in steps to give a tighter tolerance.
You can buy thread chasers that will just clean the crap out without removing material.
- First Name: craig
- Last Name: leach
Good point Dodge,
I have a old tap that I cut off so it takes the thread all the way to the bottom. The leading & trailing edge have been removed & the sharp O. D.
on a coarse wire wheel so it will not cut any metal. I have had it since the 70s when I rebuilt skinny block Chevys. A new sharp tap will destroy a
block. Do use the tap that comes with, for the insert.
Since I discovered threadserts/keyserts, they have become my thread repair of choice. Some advantages are;
They can be fitted without the need for specific taps which are used on helicoils. Just use a standard tap from your tool stand.
They come in varying wall thicknesses so a more flogged out hole can still be accommodated but still.retain the correct finished size.
They can be used in open ended applications like the bottom eye on a front axle, without the chance of them winding through when the spindle bolt is fitted.
With no nèed for special taps they tend to be less expensive.
mbowen
- First Name: Miles
- Last Name: Bowen
I too used a junk head as a drill guide. I drilled out the one hole on the junk head to the larger size on the drill press to keep the hole square to the deck, then snugged it down to the block with the remaining bolts to ensure proper location.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
muzzjb
- Last Name: Bodor
Thanks for all the replies.
I got the hood former and wood firewall out, but the firewall came out in a few pieces, it was pretty fragile. In fact it was already split/broken in a couple places before I removed it...so it came out from around the steering column. Guess I'll take the opportunity to make a new one, and do a proper steering column removal. I want to replace all the bolts anyways...are the firewall bolts a specific part number, or are they just carriage bolts? Is it a good idea to replace the pitman arm at the same time?
The good news is that with the firewall and hood former removed, there was enough room to get a drill and bit in to drill out the back hole. I used a drill guide to keep it perpendicular. Now to do the other holes...
Not as a general rule. If it's in good condition just reuse it. Inspect the ball for wear, (undersize, not round, etc.) Also, have a close look at the woodruff key and keyway. There should be no slop between the key & keyway.
RGould1910
- Last Name: Gould
I use a guide block for the tap too. A tap wont always follow the hole straight. A head won't work for that unless you enlarge the hole In the head. You may need a tap extention too. Its a headache to do all that, but you get a good job.
