F/S 16-20 fan
Topic author - Posts: 1998
- First Name: craig
- Last Name: leach
F/S 16-20 fan
16-20 steel fan hub, good barrel for belt tight rivets, bushings a little loose but serviceable. $55 + shipping.
Karl Von Neumann
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Re: F/S 09-16 fan
Fan hub for 09 to 16 was brass steel is 16 and on
- First Name: craig
- Last Name: leach
Re: F/S 16-20 fan
You are correct Karl I just looked @ the blades in the parts books. Thanks for the correction.
Re: F/S 16-20 fan
Those fan blades differ from our Canadian sourced parts. On ours, the outer end of the embossed ridge tapers out to almost nothing. Those are quite definitely sharply defined at each end, more like the deeper pressings on the very early blades. Interesting! Nice example.
