1910 Holley 5 ball carb questions
RGould1910
Topic author - Posts: 1164
- Last Name: Gould
I recently acquired a beautiful 1910 Holley 5 ball and getting ready to try it out. Many thanks to Kim for offering it to me. I'm interested in hearing from others who have run these carbs. How do they perform? How are they primed before starting? Any tips, suggestions, etc. appreciated.
Re: 1910 Holley 5 ball carb questions
There is a choke & tickler.
Are there both pull rods outside the radiator? & how are they differentiated?
RGould1910
- Last Name: Gould
John, I assume the plunger is for priming before cranking and the choke used if necessary while cranking. On my 1910 style Kingston 5 ball without a plunger, I remove the cap and lift the float before cranking to prime and use the choke sparingly. I agree it's usual to see both on one carb
RGould1910
- Last Name: Gould
I would think only one choke rod would be used. I don't like to open the hood to prime. I'll attach the rod to the plunger, tickler as you say.
RGould1910
- Last Name: Gould
I just noticed the choke has a little wear on the lower arm where the rod would insert. The plunger arm has zero wear. Tells me the rod was attached only to the coke. This carb has such little wear overall, I would think what I see is what came from the factory.
KimDobbins
- First Name: Kim
- Last Name: Dobbins
Richard, my 1910 T had the same carb, only with a pot metal float bowl. I'd seal the float, that was such a nice carb I never even took it apart until I photographed it for you. To start the engine, I'd depress the float plunger for a few seconds then pull the engine through 4 quarter turns then turn on the battery and it should start. Try 1 turn open on the needle valve.
Aussie16
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 RHD Canadian Touring 1916 Pickup 1926 Fordor 1925 Dalgety Tourer 1916 Speedster
Does the Holley have hidden Balls? I am familiar with the era equivalent, the Kingston 5 ball with its 5 screws to access the balls. I have never heard of the Holley being referred to as a 5ball variant. My education continues.
AndreFordT
- First Name: Andre
- Last Name: Valkenaers
Hi all,
I don't think this is a five ball carburetor but a HOLLEY #4150 used in 1910. "Judging Guidelines Model T Carburetors Part II picture #4 and #5."
Just my idea.
Andre
Belgium
Just my idea.
Andre
Belgium
RGould1910
- Last Name: Gould
Andre you're correct, the balls are hidden under the top cap which is removable. I also have a 1911 Holley which is different. It has an.air valve with a single heavy weight inside an adjacent chamber.
Thanks for the help, Kim.
KimDobbins
- First Name: Kim
The balls are hidden as Richard says, and smaller then the more common Kingston 5 ball.
RGould1910
- Last Name: Gould
Another beautiful carb Kim. I swear I still don't know how you've acquired so many rare pieces in such remarkable condition!
I spoke with Steve at Langs and he recently acquired a pot metal 1910 Holley like yours but needs a new bowl.
That's not gonna be easy to replace.
