Support Forum
chippy74@bigpond.com
- First Name: Matthew
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 19## TT ton truck, 19## T Pickup
Post
by chippy74@bigpond.com » Thu Jul 11, 2019 7:25 pm
1925TT
- First Name: Forest
- Last Name: Ledbetter
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT Holmes tow truck
- Board Member Since: 2014
Post
by 1925TT » Thu Jul 11, 2019 7:37 pm
I think the pieces missing are the locking pieces that go where the holes are in the rim. You should also have the retention ring. I've attached a photo of our rebuilt wheels. The outer ring and lock ring are both in silver but you can see the split.
- 576~2.jpeg (38.41 KiB) Viewed 7273 times
1925TT
Post
by 1925TT » Thu Jul 11, 2019 7:40 pm
Yours may be a single piece outer rim. It's hard to tell from the picture. As for the tires, we put 700 20s on ours.
Post
by Allan » Thu Jul 11, 2019 8:38 pm
They look like one piece rims to me, like those used on 21" wood wheels on 26-7 T's. The rusty one looks to have the latching mechanism missing at the join. If you take the other one off the wheel, hopefully that will show you what is missing.
Hope this helps.Allan from down under.
D Stroud
- Last Name: Stroud
- Board Member Since: 2011
Post
by D Stroud » Thu Jul 11, 2019 8:59 pm
Matthew, the wheel and rim on the right and the rusty rim are Kelsey 23", they use a 32x4 1/2 tire, some times a 33x5 tire is used. They are 23' rims, but are not made for clincher tires(30x3 1/2). The wheel on the left appears to have a wood fellow, I have no idea what it is. It does appear to have a TT hub in it. It is probably an aftermarket or one that has been adapted from another vehicle. Hope this helps. Dave
1925 mostly original coupe.
- First Name: Dallas
- Last Name: Landers
Post
by Dallas Landers » Thu Jul 11, 2019 9:54 pm
Not a good close up and flat tire but this is the 23" kelsey wheel Dave is talking about. I am running 33x5 tires.
Post
by Steve Jelf » Thu Jul 11, 2019 10:28 pm
There's always plenty of confusion over similar terms when this subject comes up. Matthew''s demountables are split RIMS. Notice that the rim is split all the way across. There is no separate ring. The holes are for the missing hardware that should hold the rim together. Forest's's picture shows a split RING. Notice that only the separate ring has a split, and there is no split in the rim. The split ring is the one that famously wants to kill you, and is often installed in a cage or with chain wrapped around it to prevent that misfortune.
Steve Jelf on Thu Jul 11, 2019 11:00 pm, edited 1 time in total.
D Stroud
- Last Name: Stroud
Post
by D Stroud » Thu Jul 11, 2019 10:40 pm
Steve, look again. Forest's wheel is a split ring, it's a 20" wheel. Matthew's is a 23" Kelsey wheel split rim, Kelsey didn't make a 23" split ring rim as far as I know. Dave
Post
by Steve Jelf » Thu Jul 11, 2019 11:02 pm
Oops! I switched the names. Correction made. Thanks, Dave.
1925TT
Post
by 1925TT » Fri Jul 12, 2019 12:14 am
Yeah, i should have caught that.
- Last Name: Brown
Post
by chippy74@bigpond.com » Fri Jul 12, 2019 3:00 am
Thanks fellas I assume the rim is split to allow fitting of the tire before clamping the wheel into the rim.
1925TT
Post
by 1925TT » Sat Jul 13, 2019 2:23 am
Yep. They made a tool for that.
- s-l300 (1).jpg (14.5 KiB) Viewed 7082 times
- Last Name: Brown
Post
by chippy74@bigpond.com » Tue Jul 16, 2019 2:53 pm
Sorry for the delay in my reply, Dallas in your photo is there anything held between the wheel felloe and the spit rim by the wheel clamps it looks as if there are several lines or pieces where on the wheels I have there is gap when the rim is placed over the wheel.
As always any help is greatly appreciated.
Post
by Dallas Landers » Tue Jul 16, 2019 3:59 pm
Matthew, nothing at all. The rim has cuts in the square bead, Im guessing its easier to form the rim this way. One notch that slides together on the splut in the rim. No seperate ring on these rims. Here is a photo of my spare rim.
D Stroud
- Last Name: Stroud
Post
by D Stroud » Tue Jul 16, 2019 10:36 pm
Some of those Kelsey rims used a seperate ring and some didn't, I've had both. I believe the ones that didn't have the rings were later and probably easier and cheaper to make, although that is just a guess. I've also had rime that had the cuts in them and ones that didn't. The ones on Dallas's TT have the cuts, and they aren't all spaced evenly. To me it looked like they sawn by hand, probably as was said to make them easier to mount and break down the tires. If so, it must have been a popular modification as I've seen a lot of them, also a lot that didn't have them.
Dave
- Last Name: Brown
Post
by chippy74@bigpond.com » Wed Jul 17, 2019 1:35 am
Thank you everyone a bit of research armed with your advice has reveled that the rims I have require a clamping ring that I have been able to source from the same guy I obtained the wheels from but now I have discovered a small rust hole in one of the rims any advice on how I would repair the rim would be as always greatly appreciated.
- DSCN0472.JPG (90.58 KiB) Viewed 6958 times
- DSCN0470.JPG (89.22 KiB) Viewed 6958 times
D Stroud
- Last Name: Stroud
Post
by D Stroud » Wed Jul 17, 2019 4:02 am
Dallas, look at those back tires again. They're 32x4 1/2, unless you've switched them.
Dave
Post
by Dallas Landers » Wed Jul 17, 2019 7:04 am
Dave is correct. 23x5.00 tires ( 32x4 1/2) Lucas
