If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
D.Yoder
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Post
by D.Yoder » Sat Jul 13, 2019 6:11 pm
for three years I have tried to trace down a knock that has bugged me since I built it.
Think I found it.
KeithG
- First Name: Keith
- Last Name: Gumbinger
Post
by KeithG » Sat Jul 13, 2019 6:21 pm
Dean, It's great that you finally found it, but are you going to share what you found with the rest of us?
Thanks,
Keith
Burger in Spokane
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Post
by Burger in Spokane » Sat Jul 13, 2019 6:29 pm
I am guessing it was the use of plywood behind the electrical panel (?).
Les Schubert
- First Name: Les
- Last Name: Schubert
Post
by Les Schubert » Sat Jul 13, 2019 6:42 pm
Having no information, I’m guessing cam shaft end play!! It can really drive you crazy!!
D.Yoder
- First Name: DEAN
- Last Name: YODER
Post
by D.Yoder » Sat Jul 13, 2019 7:24 pm
After I drive it and am positive what it was I will share .no one has hit it yet
Tony_H
- First Name: Tony
- Last Name: Howard
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tourer 1925 Coup
Post
by Tony_H » Sat Jul 13, 2019 7:33 pm
Government - because people struggle to ruin their lives by themselves
Kerry
- Last Name: van Ekeren
Post
by Kerry » Sat Jul 13, 2019 8:11 pm
Now I'm sure everything would have been sweet when Dean rebuilt the engine so I'm putting my money on a sneaky little knock on the scat hitting the pan horse shoe or one of the bolts holding it.
D.Yoder
- First Name: DEAN
- Last Name: YODER
Post
by D.Yoder » Sat Jul 13, 2019 10:39 pm
Not the scat crank hitting .checked that couple years ago.
Adam
- First Name: Adam
- Last Name: Doleshal
Post
by Adam » Sun Jul 14, 2019 9:37 am
Rod bolt barely tapping the cam? Loose flywheel bolt?
D.Yoder
- First Name: DEAN
- Last Name: YODER
Post
by D.Yoder » Sun Jul 14, 2019 12:05 pm
Not the rods. I have checked them three times
D.Yoder
- First Name: DEAN
- Last Name: YODER
Post
by D.Yoder » Sun Jul 14, 2019 12:12 pm
Flywheel bolts so tight I thought I was going to have a cheater bar to get them off.
Joe Bell
- First Name: Joe
- Last Name: Bell
Post
by Joe Bell » Sun Jul 14, 2019 5:31 pm
Had one that drove me nuts, .060 over Egge's with the sharp edge on side was hitting head gasket, Another one was piston hitting top of cylinder on high rpm's with High Compression head.
aDave
- First Name: David
- Last Name: Dufault
- * REQUIRED* Type and Year of Model Ts owned: 1915
Post
by aDave » Tue Jul 16, 2019 10:27 am
Ohhhh - the suspense....
Anxiously awaiting the answer...
- suspense.jpg (10.01 KiB) Viewed 9254 times
ShirkWood
- First Name: Verne
- Last Name: Shirk
Post
by ShirkWood » Tue Jul 16, 2019 10:53 am
Bent rod or piston slap?
HaroldRJr
- First Name: Harold
- Last Name: Schwendeman
Post
by HaroldRJr » Tue Jul 16, 2019 8:58 pm
Crankshaft pulley/pin assembly?
D.Yoder
- First Name: DEAN
- Last Name: YODER
Post
by D.Yoder » Tue Jul 16, 2019 10:34 pm
Removal of one shim cured my knock.
Kerry
Post
by Kerry » Wed Jul 17, 2019 12:26 am
Sounds like you were lucky that your engine didn't eat the magneto
aDave
- First Name: David
Post
by aDave » Wed Jul 17, 2019 9:45 am
Interesting.
So, for further education, why was the shim installed? For some reason it was put there....the result was not to your liking - (nor to the engine's)...is there a lesson to be learned here that you can share with us?
Incidentally - many thanks for the expertise you have shared in the past!
Dave
D.Yoder
- First Name: DEAN
- Last Name: YODER
Post
by D.Yoder » Wed Jul 17, 2019 1:33 pm
Dave the biggest lesson is 25- 40 clearance loose
25.
The shim I used is a factory shim.
I made it too tight.
Scat cranks have a large radius fillet if I am setting another scat. On the tight end I will check my radius fit with plastigague.
aDave
- First Name: David
Post
by aDave » Wed Jul 17, 2019 2:57 pm
Thank you.
Another lesson I hope to file away between my ears. (But I will write it down to count for the inevitable "forgetfulness"
