Water Neck Question
Topic author - Posts: 844
- Last Name: Clements
Water Neck Question
What is this water neck? It is leaking out of what appears to be rubber in the center of that brass nut.
- First Name: Henry
- Last Name: Lee
Re: Water Neck Question
An old circulator water pump accessory. Sometime long ago the drive was removed and plugged.
Hank
Hank
Should I just remove it and replace it with an original type water neck?
- First Name: Henry
- Last Name: Lee
Would not hurt.
Hank
Hank
Would be best removed, sometimes the old impeller mechanism may still be in place, or at least casting parts, these can block the thermo-syphon action of the Ford cooling system. Plain Ford part is better.
I was able do a "depression era fix". I cut a piece of inner tube patch and replaced the rubber button. It is sealed for now and was able to take the wife out for a sunset cruise. I will definitely replace it asap.
Scott
Here is what that 'Nims' brand water pusher looked like when new. A plug on the side of yours was the grease cup for the bushing, and a pulley ran a narrow secondary belt over the Ford belt to drive the impeller.
- Last Name: Hanlon
Scott, I have several improved style water outlets, with nice pullies. Send me an email if you're interested.
Dave
Dave
