When there is smoke there must be fire.
Topic author - Posts: 522
- First Name: Andre
- Last Name: Valkenaers
During the rebuild of en engine last Saturday I was recharging the magnets by using the coil loop that came with the engine and was looking good.
Before I tested the coil ring by building it in serie with a 12V 21W light and a 12 battery and checking the change of polarity on each coil. No problem there.
For recharging the magnets, I use three 12V battery's in serie and flash the coil ring a few times. During this there was some smoke coming out of one coil.
Result: magneto coil ring need a rebuild!!!!
First I was thinking to replace only this coil but I found there was no insulation between the coil and the cotton warp. All the loop will come apart and will be rebuild.
Andre
Belgium
Had a sort like problem awhile ago but than there was some fire too.
Andre
Belgium
- First Name: Andre
- First Name: Dallas
- Last Name: Landers
Re: When there is smoke there must be fire.
- First Name: Andre
I forgot to collect the smoke so I will need your bottle. I am also looking for a can of elbow grease and skin varnish.
Have a fine Sunday. I will be rebuilding a coil loop
Andre
Belgium
Andre
Belgium
- First Name: Jem
- Last Name: Bowkett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
Dallas, you faked that bottle! I recognise it, it's a Jaguar part.
- First Name: Rich
- Last Name: Bingham
Jem, you nailed it ! Thing is, the Jag item is compatible with all Lucas systems.
"Get a horse !"
Whooda thunk it? A T and Jag part interchangable.
- Last Name: Warren
Lucas. Prince of darkness
. And that is no joke.
- First Name: Andre
Guys, guys,
I am only going for the real stuff, no replacements only New Old Stock .
No Jaguar smoke but Model T smoke!
No monkey elbow grease but the real stuff!
No pig skin varnish but authentic skin varnish!
By the way the coil loop is nearly done.
Andre
Belgium
Andre
Belgium
- First Name: Andre
Missing two layers of polyester and one layer of isolation varnish to go and the fire is out.
Andre
Belgium
Andre
Belgium
- First Name: Andre
Nice work!!!
Looks as if the smoke will be contained nicely.
