Correct E & J Tail LIght for '13 T?
GEmering
Topic author - Posts: 339
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
Is this black and brass E & J tail light correct for a 1913 T?
Thanks,
Gene
https://www.ebay.com/itm/E-J-Ford-Model ... %7Ciid%3A1
Thanks,
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
- Last Name: House
Re: Correct E & J Tail LIght for '13 T?
Yes. Although most guys try for matching all 5 lamps as to manufacturer. I don’t. I also have a b/b tail lamp but like the looks of my b/b Jno Brown cowl lamps.
Take a look in Bruces book.
GEmering
- First Name: Gene
Larry,
I have Bruce's book.
I'm new to the hobby and saw this lamp specifically advertised for an early T (1909-1912 which should be all brass).
I thought it was for a "13 based on what I've read/researched.
Just wanted to verify, as it was specifically advertised differently.
Gene
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
Michael A
- First Name: Michael
- Last Name: Abbott
- * REQUIRED* Type and Year of Model Ts owned: 1912 C-Cab
hi, I have some problem accessing all the forums. Would this Bruce's book be available through the MTFCA. I am interested in purchasing one. Does anyone know if they are still available?
Regards Michael
Regards Michael
GEmering
- First Name: Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
Michael A
- Last Name: Abbott
Thank you Gene, their are so many combinations of brass with the black and brass cowl and tail lamps I was wondering if this book has more detail. eg some have brass mount and some have all brass tanks also the section above the steel body I have seen all brass. Would like to know on a 14 what is correct in the E&J lamps.
Michael
Michael
- Last Name: House
Well, this is one Michael. It’s unusual because of the brass immediately above and below the steel body. Sure wish I could find the mate to it. It’s E&J pat’d 1908.....Yeah, touch the picture and it’ll right itself.
Michael A
- Last Name: Abbott
Very nice lamp, some have brass mount on the back.
I don't think that style was used on a Ford.
