Line boring early block
Erik Barrett
Topic author - Posts: 537
- First Name: Erik
- Last Name: Barrett
- First Name: Henry
- Last Name: Lee
Re: Line boring early block
That's an early Puppy Erik!'
Hank
Hank
modeltbarn
- First Name: Gary
- Last Name: London
Is that Mike's?
Erik Barrett
- First Name: Erik
Yes it is an early one. Number is just over 5000. I know the owner as as Micheal.
John Warren
- Last Name: Warren
Thanks for sharing Eric. Always great to hear from you.
otrcman
- First Name: Dick
- Last Name: Fischer
Interesting picture, Erik. I've never actually seen a line boring operation, so maybe this is a dumb question (won't be my first ........ or last).
I notice that the block is not clamped down to the table. As a matter of fact, it appears to be sitting on a cushion of shop rags. So, what keeps the block aligned to the machine's drive during the boring operation ?
Thank you,
Dick
Thank you,
Dick
NorthSouth
- Last Name: California
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up, 1924 PACO Bodied Speedster
If I remember my lessons from Rumble Seat Garage, the above photographs show only the first stage of a finely tuned two jig boring process.
KimDobbins
- First Name: Kim
- Last Name: Dobbins
Erik, if you lay a standard crank in the bearing surfaces, how much wear if there? Or was the block previously babbited?
Erik Barrett
- First Name: Erik
The block is clamped down through the cylinder bores. The rags are there to protect the deck surface from scratching. The mill drives the bar with a flexible coupling so perfect alignment is not required, but I get it close. This block has been opened up to use babbit on the upper main bearings. Originally it would have run the crank in the iron bores.
