Can someone explain, in detail, with pictures if necessary, how to remove the glass from the frames and doors of a Center Door with the latch system.
I need to replace the felt channels and I am baffled.
Thank you and thank you.
Glass removal
Topic author - Posts: 936
- First Name: William
- Last Name: Vanderburg
Glass removal
William L Vanderburg
1922 Center Door Sedan
- Last Name: Rutt
- * REQUIRED* Type and Year of Model Ts owned: 1926 fordor
Re: Glass removal
Search window channel replacement on this forum.. I remember there being a detailed instruction.
Re: Glass removal
The same question has been asked about glass removal in the Coupes and 2-4 door Sedans. It usually involves removing the inside door panel, any type of window regulator and mounting boards brackets and door latches if necessary.
Once those are out then remove the door/window trim pieces. Slide the glass down so you can remove the tacks in the window channels. Slide the window up to remove the tacks at the bottom of the glass channel. The glass should come out at the lower portion of the door
If the glass and window channel was put in it will come out in reverse order.
