Special Spring for Watts Clutch?
Last Name: Strange
Post by CudaMan » Mon Aug 12, 2019 10:20 am
Hello, I have a set of Watts clutch disks, but I understand that the Watts clutch uses a special, stiffer than stock spring.
Does anyone know the specs of that special spring? X pounds at an installed height of Y inches? or Z% stiffer than the stock Ford spring?
Re: Special Spring for Watts Clutch?
Post by Mark Gregush » Mon Aug 12, 2019 10:35 am
I am pretty sure it is 110-115 at 2 inches. I did a little searching and all I could find was it had a higher rate then normal. I think normal rate for Ford is about 90 at 2 inches. The stack height of the disks will be the same as stock, 1-1/8" with large Ford disk on top and bottom.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Mon Aug 12, 2019 10:38 am
Mark is correct. Chaffin's makes the heavier spring.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Aug 12, 2019 11:00 am
Can you still buy the Watts clutch? I had one in a speedster years ago and really really liked it. I figure it helped “preserve “ the rear axle gears!
Last Name: Strange
Post by CudaMan » Mon Aug 12, 2019 11:38 am
I think R.V. Anderson is tooling up to produce them again. The one I have is an original set I bought on Ebay years ago. I see there is another original set of clutch disks on Ebay right now.
I think I'll order the stiffer spring from Chaffin's today so that I have it ready if/when I install my Watts clutch disks. :)
hah
Last Name: hardiman
* REQUIRED* Type and Year of Model Ts owned: 26 coupe
Post by hah » Mon Aug 12, 2019 2:25 pm
Is this stiffer spring only limited to watts clutch?
Chaffins
First Name: Herbert
Last Name: Chaffin
* REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1911 touring, 1913 roadster, 1914 touring
Post by Chaffins » Mon Aug 12, 2019 3:37 pm
Our new Clutch Spring has a force of 110-115 lbs at 2 inches. It can be used with any Ford clutch set up. Glen
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Mon Aug 12, 2019 6:03 pm
Mark S: I am currently making the Watts style clutch.
rvmodeltATnetsyncDOTnet
