Can anyone identify this nos aftermarket radiator close to a Model T but taller
Topic author - Posts: 1697
- First Name: ROBERT
- Last Name: BERGSTADT
I just got this radiator in it is nos from a very old aftermarket
customer who had this says he had owned it since the 50's and he got it from a farmer
pictures not the best because its sitting on a white pad very clean
the neck and shape of the tank are different as well is the inlet and outlet
very similar to a T
measures about an inch taller than a high radiator and about one and a half inches narrower
23 3/8 tall from top of tank to bottom of tank
18 7/8 wide
notice the stamped mounting plates and where the overflow tube is mounted
any help appreciated, Bob
very similar to a T
18 7/8 wide
- Last Name: Hanlon
Re: Can anyone identify this nos aftermarket radiator close to a Model T but taller
Totally WAG, coming from a farmer, I bet it's for a tractor...
The stock radiator on my 25 is just under 24" top to bottom. So 23-3/8 would be just a little short but not enough to worry about.
could it be Metz?
Bob
Bob
- First Name: Bill
- Last Name: Harper
- * REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Hi Bob,
No, it is not a Metz radiator, well, it is not for the Model 22 or the Model 25. I can't speak to the later 6 cylinder cars, but I doubt that it would fit.
Could it be intended to be used with one of the period aftermarket speedster kits with a higher radiator shell?
Bill Harper
Keene, New Hampshire
Please read my post. It is just a about the same or just little shorter then a stock T high radiator. Not including the neck, from the bottom to top.
when I pit a high shell on it its about a inch from the mounting plate if I remember right I will try when I get back to the shop, Bob
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
Bob, What is the measurement between the mounting points to the car frame ? Per your measurements the core is 18 7/8" wide, a stock Model T uses 21 1/2" wide between mounting points. It looks like it could be close to stock T width, if so, maybe it fits a custom speedster body of unknown to me make.
The radiator looks like a tractor radiator from the 40’s and 50’s. Not for sure but tractors in that era had radiators similar to a T. But also it could be for a car in that era. Try a high T radiator shell and see how it fits. Then you would know for sure. Maybe the rubber pads are used for spacers to raise it up besides used for cushioning.
- First Name: Dallas
- Last Name: Landers
No guesses but not many tractors had the hood rod down the center.
Pictures from the 2016 forum of what is thought to be a Morton Brett radiator. Notice that the radiator core construction is similar to this radiator.
http://www.mtfca.com/discus/messages/59 ... 1470717303
