Repair for steering box “slot”
Topic author - Posts: 1359
- First Name: Les
- Last Name: Schubert
Visiting with a model T friend yesterday we got discussing a repair for “walleyed out” travel limiting steering box slots. How big a problem is this? We have come up with a solution that would probably make it better than new!
Re: Repair for steering box “slot”
Les;
A 26 coupe I have been doing some work on has the same problem. I am going to come at it in maybe a different way. I welded a pad on the drivers side spindle arm to limit it's travel. Hard turn to the left and the pitman arm goes over center, to the right no problem. I still have to fit the arm to the spindle an see if it needs more or less pad then I have it now. I took a que from the Model A setup. The nut that holds the king pin lock does the same thing, limiting the spindle travel.
- First Name: Henry
- Last Name: Lee
Les,
If required you can mount on a rotary table on the mill and relocate at a different area. Just an idea.
All the Best,
Hank
All the Best,
Hank
- First Name: Henry
- Last Name: Lee
120 degrees out and relocate the pin to match it’s new home.
- First Name: Les
Henry
That’s a really good idea. Probably easier than mine
Hank
If you had this done in TN, do you think NASCAR boys at the shop might offset the new groove a little bit CCW to encourage only left turns? I know you're not near Tri-Cities, but bet you know a few fellers.
Probably not much of a risk for someone living in Calgary, though.
- First Name: Henry
- Last Name: Lee
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
Scott, Forget the NASCAR boys, a true 1920's dirt track team all the way up to a 2019 outlaw sprint car team would have milled the steering slot to turn more to the right. Every dirt track racer knows you turn right to go left. Just kidding a little.
Kevin
point taken!
point taken!
