Is there a supplier for the 2 small nails used in the Ignition coil to hold the cover on?
thank you, Erick
Nails for ignitions coils
Re: Nails for ignitions coils
You should be able to find the wire brads at a good hardware store. Personally, I staple the door in place. Makes it easier to get into later if needed.
The 1914 and earlier KW coils use brads. I don't know about the other brands. Check with RV, he knows for sure.
