Elbow bolts
Last Name: Juhl
Elbow bolts
Post by Oldav8tor » Wed Sep 11, 2019 9:39 am
Quick question - If I remove a bolt from the elbow (cooling system) attached to the side of the block will coolant run out of the hole? I may need to install a bracket and want to know if I need to drain the coolant down before doing so.
First Name: Henry
Last Name: Lee
Re: Elbow bolts
Post by Henry K. Lee » Wed Sep 11, 2019 9:45 am
Normally it should not be a problem. Just make sure you do not bottom out in the thread well straining the boss. The threads do not go into the cooling system unless someone before you over did it.
Hope this Helps,
Hank
Re: Elbow bolts
Post by Mark Gregush » Wed Sep 11, 2019 10:27 am
Why risk making a mess if the water inlet pulls loose, just drain the radiator.
Re: Elbow bolts
Post by RajoRacer » Wed Sep 11, 2019 11:43 am
No worries IF you're just removing 1 bolt.
Re: Elbow bolts
Post by Mark Gregush » Wed Sep 11, 2019 12:07 pm
if it is just one bolt, go for it. I was thinking horn bracket. ;)
Last Name: Juhl
Re: Elbow bolts
Post by Oldav8tor » Wed Sep 11, 2019 7:25 pm
I may drain the radiator down some just in case. It would be just one bolt at a time but then again, why risk it? I'm waiting on a horn I bought from Hank and don't know if I'll use the bracket on it or adapt it to the one already installed.
Thanks for your comments :-)
Re: Elbow bolts
Post by TRDxB2 » Wed Sep 11, 2019 8:05 pm
You can also park (or jack up the rear) to cause the water inlet to be higher than the water level in the radiator.
Last Name: Seth
Re: Elbow bolts
Post by perry kete » Wed Sep 11, 2019 8:25 pm
Unless you pry on the elbow and break the seal between the head, gasket, and elbow you will not have a leak by removing one bolt to attach the horn bracket. Everything is "welded" together by the paper gasket and any sealer used to attach the gasket. If it does weep a little it will stop when you replace the bolt and horn bracket and tighten it down. I have removed that bolt at different times to remove my horn and never had an issue.
Mark Osterman
Last Name: Osterman
Re: Elbow bolts
Post by Mark Osterman » Thu Sep 12, 2019 8:18 am
“Water inlet”
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Elbow bolts
Post by Rich Bingham » Thu Sep 12, 2019 9:49 am
Please show us a picture of a Model T in that position.
"Get a horse !"
Re: Elbow bolts
Post by TRDxB2 » Thu Sep 12, 2019 11:36 am
:lol: steeper slope needed
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Elbow bolts
Post by Rich Bingham » Thu Sep 12, 2019 2:43 pm
Much steeper ! :lol: great photo !! Thanks for posting it !
"Get a horse !"
Re: Elbow bolts
Post by Original Smith » Fri Sep 13, 2019 10:25 am
How about water inlet bolts?
