tripple gear bushings conversion to needle bearings
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Sat Sep 14, 2019 12:03 am
Just to keep the beat going on... I have been very interested in reading each and every post with great interest. Thanks to each. I was also happy to see that nobody was getting beat over their posting!
Jeff. I'm not totally sold on those needle bearings as being better than the original bushings. I trust Dan's expert work and advice but have seen those very tiny bearings not survive what the bushing would endure. YMMV
1912 Torpedo Roadster
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: tripple gear bushings
Post by Dan McEachern » Sat Sep 14, 2019 12:41 am
I'm outa popcorn, BUT- Gene if you or anyone else knows of a case of my needle bearing conversion failing, I would sure like to know about it. The needle bearings have never failed as far as I know, and the reason is they are a 100% engineered solution to an ongoing problem that will never go away regardless of the amount of clearance one gives or does not give to those bushings. This subject eventually drifts toward the metallurgy of the bushing material, Z bronze etc, but never really addresses the fact that a bushing that size cannot develop and maintain a proper oil film to prevent metal to metal contact given the loads involved. I've done the calculations and the numbers don't lie - that's why I developed the needle bearing conversion over 20 years ago, and the original protoptype is still running in a regularly driven car with no issues what so ever. Thanks, Dan
AdminJeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Re: tripple gear bushings conversion to needle bearings
Post by AdminJeff » Sat Sep 14, 2019 1:31 am
I split this topic as there has been so much interest in this conversion it's worth a discussion. I've heard privately from no fewer than 5 folks who swear by it and have been running it their cars for 20 some odd years with great results. The mechanical theory is sound, the triple gear design screams for it, and it just makes sense. Needle bearings have been used for decades in many high-stress applications and especially racing transmissions - ie Formula One (my wife has a Fernando Alanzo transmission needle bearing neckless that cost me $250 in Paris), and this application should be no different. Certainly better than the current bronze bushing that causes so much grief for so many.
And in this case it doesn't subscribe to the "if it aint broke don't fix it" adage - this is broken. It's obviously a bad design from the outset. Witnesses the countless folks who have clearly suffered from this issue, and it's conjecture at best to ascribe all of the the failures to incorrect fitment clearances. Mine included. I was there, live and in person, when we set it up.
Purists can disagree and come to my place and climb my hill in their T every day in low Ruckstell and then see how they feel. Perhaps my application is extreme. So be it. I'm putting Dan's needle bearings in my triple gears so I never need to worry about climbing my hill again.
Jeff
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
Post by Scott_Conger » Sat Sep 14, 2019 9:40 am
This post is for new owners of Model T's, so that they may go forward in their ownership of restoration or improvement with perspective of the machinery they are now the caretakers of.
If you want to call a design that was made over 15,000,000 times and survives in extrordinary numbers to this day a "bad design", I think you're being a bit harsh, don't you think? I could say that a wood-hub on a steel axle, which had to be greased every 25 miles, or so, was a bad design, too. And yet that was the state of the art when the Conestogas were crossing America, so was it really a bad design, too?
We tend to forget that we have a 100 year old design, going 2x faster than designed, and traveling 4-5 times more total miles in their reincarnated life than designed. I would submit that the exhausted relics pulled out of barns in the '50's were often totally worn out at 12,000 or fewer miles. Considering their duty as designed was to get from the farm to town. With no highways, only the extrordinarily adventurous went any distance, and when they did, it made the newspapers!
I think Dan's bearings are neat and obviously have a good track record. If bushings were the Root Cause for Jeff's failure, then he's going to be in fine shape. Was that the Root Cause?
I won't work the calculations and will accept Dan's conclusion that the bronze sometimes goes metal to metal (and by golly, that's why it's bronze/steel). Needle bearings may in fact be the "ultimate" in design for this application and maybe the way we should ALL go, but I won't bet on that. Our generation is unusually shortsighted and exhibit unusual and unwarranted superiority over all past generations when we apply today's engineering and norms and look backwards and declare something in the past to be "bad". Sometimes it was simply the best they could do. Wood and steel conquered America, and steel and bronze conquered the open road.
And now we have the technology to improve both. If they need it.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Sep 14, 2019 9:47 am
Needle bearings are far superior than a bushing due to its constant rotation in cylindrical lubrication and changing area of pressure. Some early car manufacturers knew this as well as outboard engine guys.
Just my $0.03 in the game! LOL!
Hank
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Sat Sep 14, 2019 9:52 am
I believe that these needle bearings will be the trouble free way to go.
This type of bearing is used in many applications now, pilot bearings, internal transmission bearings etc...turning much higher rpm and less lubrication.
Post by Scott_Conger » Sat Sep 14, 2019 10:20 am
Hank/Dave
If they run on a properly hardened pin that has a proper surface finish and roundness, I agree with you. They are very unforgiving to being run on soft or out of round races (pins). A search of the forum will show that all manner of really bad pins have been foisted on the public over the years, and even now, I understand that of the two suppliers of pins, one tends to be recommended and one rejected by those who understand such things.
I suspect these will be adopted with great success in shops which ensure the above, but will be met with less than stellar life in the hands of unskilled tradesmen.
AdminJeff
Post by AdminJeff » Sat Sep 14, 2019 10:49 am
If you want to call a design that was made over 15,000,000 times and survives in extrordinary numbers to this day a "bad design", I think you're being a bit harsh, don't you think? I could say that a wood-hub on a steel axle, which had to be greased every 25 miles, or so, was a bad design, too. And yet that was the state of the art when the Conestogas were crossing America, so was it really a bad design, too?.
Ok, I should have clarified. Bad design for my application, which may be similar for others. Truly groundbreaking at the time, of course, no disagreement there. And no, not harsh when we all have the luxury of 100+ years of hindsight and want to actually use these 100+ year old machines every day.
Jeff
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Sat Sep 14, 2019 10:58 am
A little OT, but I have to say...
Other posts have talked about SCAT cranks and one mentioned 4000 rpm from a T engine being possible. I believe it's true, but I have great hesitation about spinning the 100 year old tech of the Ford planetary transmission at those speeds !!
AdminJeff
Post by AdminJeff » Sat Sep 14, 2019 11:20 am
I've ridden in Robert Weitzel's T and it threw my head back. I guess anything is possible, it just depends on how often you want to fix it!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Sep 14, 2019 1:03 pm
Like Robert and Erik, high RPM’s my friend too. Not uncommon 4,000-5,000 RPM’s!
Nothing failing yet!
Hank
modernbeat
First Name: Jason
Last Name: McDaniel
* REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
Post by modernbeat » Sat Sep 14, 2019 1:15 pm
And that "T" has a newer (C4 I believe) transmission in it.
Having seen what high revs do to engines every day, and what it takes to build an engine (vintage or modern) to survive high revs, I'm building mine to provide more mid-range grunt. I'll never have the power that the high revving engines do. But I also won't have the headaches.
Jason McDaniel
paulmikeska
First Name: Paul
Last Name: Mikeska
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Speedster, 1923 Farm Truck, 1926 Coupe
Post by paulmikeska » Sun Sep 15, 2019 10:27 am
A few years ago I drove up Trail Ridge Road in Rocky Mountain National Park in my 14 Touring with a few other crazy folkss. All of the cars had ruckstell rear ends except one. It was a 26 or 27 Touring and was loaded with 4 full sized adults. It also had Dan's needle bearings in the tripple gears. That drive is tough even with a ruckstell. The car went all the way up the mountain that tops out at just a little over 12,000 feet and in low gear all the way. That sold me that the needle bearing modification from Dan is bullet proof!
Matt in California
First Name: Matt
Last Name: G
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
Post by Matt in California » Sun Sep 15, 2019 4:41 pm
Maybe I missed it, but could someone please post Dan's needle bearings price and how to order them?
Thanks,
Matt
Post by Scott_Conger » Sun Sep 15, 2019 5:31 pm
Matt
just contact him. Very easy to deal with, excellent products and very fair prices.
dmcgears@yahoo.com
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Sep 15, 2019 9:09 pm
I’ve run a essentially stock T transmission at 4000 rpm plus with zero problems. I will qualify that I oil them from the inside via a hole down the inside of the main shaft connected to the pressure oiled rear main
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Sun Sep 15, 2019 10:19 pm
I have seen many bad outcomes of needle bearings in British sports car transmission layshafts (cluster gears) over the last 40 years. Maybe triple gears are different, but I'm thinking of using bushings for my upcoming rebuild. My 2 cents... Bill
art32mor
First Name: Art
Last Name: Morra
* REQUIRED* Type and Year of Model Ts owned: 24T Touring
Post by art32mor » Mon Sep 16, 2019 12:29 am
Dan's needle bearing require new pins or forget that idea
Last 5 years I fix 2 sets of triple gear bushings but case old pins where used and the tranny bushings in the drums was way loose may been a factor
Plus we driving these cars faster and for longer periods of time might be another
So
To many variables say yep that the issue
modernbeat
First Name: Jason
Last Name: McDaniel
Post by modernbeat » Mon Sep 16, 2019 8:01 am
And I've rebuilt and modified many VW and Hewland racing gearboxes and rarely (never?) saw a needle bearing failure that wasn't caused by something else failing first. Even the crank in our racing SAAB had needle bearings on the main and rod journals, and it was "splash" oiled and had 300% the original power.
When I saw that a needle bearing conversion was available for these, I jumped on it for my car that needs all the reliability I can put in it.
And I got notification from Dan last night that they are finished and on their way. :D
Jason McDaniel
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Mon Sep 16, 2019 8:28 am
The Germans and Swedes have reputations for excellent engineering and quality, and all of Dan's products are also top notch judging from what I have seen. But if BMC was providing the needles and shafts, I would run the other way. Best of luck Jason! Maybe you could post your testimonial after you run these for a while? I might yet see the light! Cheers, Bill
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Mon Sep 16, 2019 9:17 am
In all my years on this Forum this is the 1st. time I've ever heard about this. Can't believe it.
