charging magnets off flywheel
Dennis_Brown
Topic author - Posts: 266
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
I know this has been covered somewhere before. I have a round aluminum plate given to me by an old T restorer years ago. It is drilled to allow you to mount magnets like on a flywheel. If I mount correctly oriented magnets to it can a mag coil ring be layed directly on it to try to charge the magnets or does the coil ring not have to touch the magnets.
Next how do you tell when they coil ring is in the correct location?
Can recharging this way be done using 12 volt or is higher voltage required?
The reason I am looking at doing it this way is a brass 14 -24 brass screw broke the small metal magnet retainer lodged between the ring gear and starter and the running motor stopped abruptly and inertia caused 9 magnets to break. I have quite a few spare magnets but will measure them for uniform thickness and they could use more strength.
If magnets are recharged individually with a home made wire wrapped charger do you also need more than 12 volts?
Thanks!
Thanks!
whedges
- First Name: william
- Last Name: Hedges
- * REQUIRED* Type and Year of Model Ts owned: 27 touring 26 tudor 26 runabout 15 speadster
- Board Member Since: 2008
Re: charging magnets off flywheel
I have recharged magnets with 6 volts with wire rapped about 20 turns 10 on each leg.
I've never used this method, but I don't think it matters if the coil ring touches the magnets. Try it and see what results you get. If your magnets won't hold a four pound weight, charge them individually with more batteries connected in series. I use 36 volts.
http://dauntlessgeezer.com/DG88.html
- Last Name: Strange
http://www.mtfca.com/discus/messages/59 ... 1482970081
http://www.mtfca.com/discus/messages/59 ... 1481945767
Or, make one of these.
- Attachments
- magnet charging.JPG (38.2 KiB) Viewed 4147 times
mike zahorik
- First Name: mike
- Last Name: zahorik
To efectively magnetize a piece of iron, you need to force as much magnetic flux thru it as possible and make an abrupt change in that flux. Magnetic flux is produced by ampere turns. This means high current thru a lot of turns in a coil. The other important item is to reduce the magnetic resistance of your magnetic circuit. Your magnetizer has to fit snugly to the ends of the Model T magnet, very little air gap between the two. But the process is relatively forgiving. If you do a search of the forum you will find many different approaches and they all seem to work. Testing the magnets will give you an idea of how good your magnetizer is. A charged magnet should easily pick up 3-4 pounds of iron. One additional point, closely inspect each one of your magnets for cracks. A cracked magnet will magnetize, maybe not fully, but could look good enough, yet may break once inside your engine causing a lot of damage. Anyway, here is what I use. Good Luck Mike
Chaffins
- First Name: Herbert
- Last Name: Chaffin
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1911 touring, 1913 roadster, 1914 touring
Magnets should be charged after mounting them. Pounding on the magnets with a hammer to set magnet height tends to reduce the charge..
I dislike the notion of hammering magnets to adjust the height. I charge them off the flywheel for maximum effect, then mount them with shims to bring the low ones up to a uniform height. I call a height variation .002" or .003" a perfectly acceptable range within the recommended setting of .025" to .040". As Dude Lester says, it don't hurt the runnin' of it none.
