What are these?
AdminJeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
What are these?
Post by AdminJeff » Tue Sep 24, 2019 5:34 am
They look like suspension parts and are new but I don't recognize them.
And body supports of some kind?
Jeff
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
First Name: Dallas
Last Name: Landers
Re: What are these?
Post by Dallas Landers » Tue Sep 24, 2019 6:36 am
Jeff, the 1st photo is 26-27 T windshield risers for roadster or touring.
Not sure on second photo but looks like aftermarket shocks or overload springs.
Re: What are these?
Post by RajoRacer » Tue Sep 24, 2019 11:42 am
Dallas is correct on both counts !
AdminJeff
Re: What are these?
Post by AdminJeff » Tue Sep 24, 2019 12:44 pm
How do overload springs work???
Re: What are these?
Post by RajoRacer » Tue Sep 24, 2019 1:19 pm
I have a full set - front & rear but mine have ball bearings where yours have brass wear plates - I believe the perch was reversed like Hassler installation required and those work with the original springs - Dan T. most likely has an advertisement for them - I do too somewhere.
Re: What are these?
Post by DanTreace » Tue Sep 24, 2019 1:57 pm
Here's a few adv. on these.
Have rear set only on the '23 cut-off pickup. Gives the wood bed a nice ride with loads, and kicks the frame up a tad.
On the front axle, have '26-'27 spindles that lower it, provides a nice rake to the chassis, truck like :D
This version on the rear , have large ball bearings on the leading edge to glide over the leaf spring. The flange keeps the spring stack in place as you remove the leaf clamp.
AdminJeff
Re: What are these?
Post by AdminJeff » Wed Sep 25, 2019 9:55 am
Very interesting. Thanks for the info!
Jeff
Re: What are these?
Post by RajoRacer » Wed Sep 25, 2019 11:37 am
Thanks Dan !
Doug Keppler
First Name: Douglas
Last Name: Keppler
Re: What are these?
Post by Doug Keppler » Wed Sep 25, 2019 6:55 pm
Dan the Man!
1924 Touring car
There's No Substitute for Proper Lubrication
