1926/27 Front Spring Dimensions
Bmettli
First Name: Brian
Last Name: Mettling
* REQUIRED* Type and Year of Model Ts owned: 1922 touring, 1933 Dodge
Post by Bmettli » Sat Jan 26, 2019 8:34 am
hi all,
I recently bought a set of front T springs from a swap meet, and I assumed they are 1926/27 because they had 8 leafs. There isn't much in the encyclopedia for measurements, can someone tell me what they measure for spring width and length?
Also, these are not drilled for oilers, so I'm not sure exactly what I have at this point. here's some pics:
just want to make sure these are actually T, I'm told they are not.
thanks!
Re: 1926/27 Front Spring Dimensions
Post by DanTreace » Sat Jan 26, 2019 10:16 am
8 leaf (late: 1926-27)
Length of Spring Leaf // and Overall Height of Ea. Leaf from flat surface
8-13/16" / 9/16"
11-9/16" / 13/16"
14-13/16" / 1-1/8"
18-5/8" / 1-7/16"
22-5/8" / 1-7/8"
27-1/8" / 2-1/4"
31-5/8" / 2-11/16"
33" / 3-5/16"
Your spring appears to be an aftermarket version, the sharp angle clipped edges are un-like Ford mfg.
Post by DanTreace » Sat Jan 26, 2019 10:27 am
For ref. to the Ford style ends of the leafs, this work by John Regan from the prints of Ford springs. Good way to i.d. Ford parts vs. aftermarket.
cfruoff
First Name: Carl
Last Name: Ruoff
* REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1927 Tudor
Board Member Since: 2011
Post by cfruoff » Sat Jan 26, 2019 12:12 pm
I believe Model T spring leaves are 1 1/4" wide, at least they are on my model Ts (a '25 Coupe and a '27 Tudor). Model A springs (I own a '29 Tudor) are 1 1/2" wide.
Shouldn't the height of the main leaf be measured from the centers of the spring eyes?
Carl
Post by DanTreace » Sat Jan 26, 2019 2:34 pm
Carl
Yes, Model T front springs are 1 /14" wide , rear springs are 2" wide.
Perhaps if making spring leafs, measures are from center of eye, without Ford prints, hard to know.
These measures are easy to use at swap meets, the eyes resting on flat surface, and tape measure up to the center bolt hole :D
For distance between eyes, (perch mount) measure for the Front springs.
31-5/16" to 31-1/2" 7 or 8 leaf
7-Leaf Front spring, center of eye to center of eye.
rondupree
First Name: Ronald
Last Name: Dupree
Post by rondupree » Sat Jan 26, 2019 3:46 pm
I cannot tell from your pictures, but an easy way to see that a spring is for a Model T is to look for the oil hole at the spring eye. Model A's, for example, have the oiler built into the shackle so they did not have to have the spring eye drilled for the oiler.
Ron Dupree
Ron Dupree
Bmettli
First Name: Brian
Last Name: Mettling
Post by Bmettli » Sat Jan 26, 2019 5:41 pm
this is all great, thanks you guys
cfruoff
First Name: Carl
Last Name: Ruoff
Post by cfruoff » Sun Jan 27, 2019 12:03 am
Thanks everyone for the useful information!
--Carl
Banjoe
First Name: Joe
Last Name: Lucas
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
Post by Banjoe » Sun Jan 19, 2020 2:26 pm
What an excellent discussion.
I was trying to sort out front spring confusion and Dan Treace provided a link to this valuable discussion.
Although not what I wanted to hear, it was just what I needed to hear and explains why my front springs are 1 3/4" wide instead of the normal 1 1/2". You also explained why there are oiler holes in the rear spring eyes but none are in the front. Clearly someone has fitted a Model A spring set at some point in this vehicles challenged past. Not sure what they did to the frame to make this wider spring assembly fit so will have to check this out closely and see if things are recoverable.
Thank you all for sharing your wisdom,
Joe
“We don’t do these things because they are simple, we do them because we thought that they were simple”.
