Proper torque for manifolds on 1920 roadster?
Topic author - Posts: 28
- First Name: Jed
- Last Name: Welsh
- * REQUIRED* Type and Year of Model Ts owned: 1920 Roadster pick-up
What is the Proper torque for manifolds on 1920 roadster?
- Last Name: Humble
Re: Proper torque for manifolds on 1920 roadster?
Same as a coupe or touring, hand tight with a short handled ratchet wrench. For head bolts torque matters, for most other bolts no.
Only a 3/8” thread, use a 7” long sm. handle ratchet , you’re only compressing the soft gland gaskets, if you have to use a fancy torque wrench, max of 15 lb/ft or so.
- First Name: Jed
- Last Name: Welsh
I use what I got. I happen to have one of those fancy torque wrenches from my young days.
Thanks for the help, Jed
You tighten a nut until just before it strips.
- Last Name: Stroud
- Board Member Since: 2011
Or, tighten it up until it strips, then back off half of a turn.
I know, it doesn't make sense, but that's one of the expressions that I grew up with from back in the early '50's, sort of like "jack up the radiator cap and roll another car under it", to describe a badly worn out (junk vehicle) vehicle.
Dave
1925 mostly original coupe.
- First Name: Jim
- Last Name: Riedy
The one I remember was " Tighten till failure then 1/4 turn" seems about right.
. Jim
