Grif-Ho Non Glare Dash Light
patelie
First Name: patrick
Last Name: Elie
Post by patelie » Wed Nov 06, 2019 12:52 pm
Hello
While making a research with Google I found, on your 2010 Forum, an equipment which I am in need.
http://www.mtfca.com/discus/messages/11 ... 1289752751
It appear that this same Dash Light was also used in the cockpit of the Douglas C-47 aircraft and, while in the process of restoring one of these aircraft I need to find three Dash lights.
I know that it's an old equipment but, perhaps, there will be someone on this forum who will be able to guide us in the right direction or who own, on a shelf, this equipment.
Thanks in advance for your help.
Re: Grif-Ho Non Glare Dash Light
Post by DanTreace » Wed Nov 06, 2019 2:38 pm
Finding those today may be a task, you might just find modern replacement of a shielded lamp like this small trailer license plate lamp.
https://www.raneystruckparts.com/4-led- ... gIM5vD_BwE
Post by TRDxB2 » Wed Nov 06, 2019 3:34 pm
Good idea - Another license plate light (other colors available) https://www.zoro.com/grote-license-plat ... gLrXPD_BwE ZORO is like AMAZON
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Wed Nov 06, 2019 6:14 pm
I believe I have one of these.
As soon as it warms up I will check for you.
It was a cool light so I bought it thinking it would look good in my PACO speedster.
If it fits your aircraft restoration it should be in that aircraft.
Harry
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Fri Nov 08, 2019 8:11 pm
Was warm enough to check my sea can for parts today.
Yes I do have on of these lights.
It appears to be tin or cadmium plated then brushed over with flat black paint.
Good possibility it was military.
If you needed more it might be worthwhile scanning this one to replicate it with a 3D printer.
This one could be functional and the others static models.
Harry Lillo
Calgary
patelie
First Name: patrick
Last Name: Elie
Post by patelie » Sat Nov 09, 2019 1:10 pm
Thanks to All.
We found three of them at an aircraft supplier I remembered.
Terry_007
First Name: Terry
Last Name: Bond
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Chassis
Post by Terry_007 » Mon Nov 11, 2019 9:17 pm
Somehow I'd missed that earlier forum posting, but good to see more info on these. I've had a display box of them in by recreated old auto parts store. The are displayed in an antique showcase along with some other lighting stuff. Interesting that the inside lid of the box folds up to look like a dashboard, with the light installed. Glad you have found some that can be used in your restoration project. I'd always thought the name looked familiar, and was surprised to see the identical logo on a stamped metal toilet paper holder in a public restroom.
Terry
