Anti-freeze
Topic author - Posts: 16
- First Name: Art
- Last Name: McTevia
- * REQUIRED* Type and Year of Model Ts owned: 1924 Runabout
Anti-freeze
I smell Anti-freeze 2 minutes after driving.I see no leaks anywhere.Head and block have been shaved.I haven't tightened the head bolts sense rebuild 4 years ago.
Re: Anti-freeze
Check freeze plugs, over flow tube (over fill will pump out), hoses and water pump if you have one. Might not hurt to retorque the head, 45-50 is good. If there is no white smoke or leaks around the head more then likely one of the above.
- Last Name: Strange
Re: Anti-freeze
I suspect the system is just a little over-filled. It should find its own correct level after a few good drives. Occasionally check the level and make sure it continues to cover the tops of the cooling tubes.
