What is the Axle shaft diameter ?
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Thu Nov 28, 2019 6:48 pm
What is the standard and minimum diameter of the axle shaft where the Hyatt rides !
Re: What is the Axle shaft diameter ?
Post by RajoRacer » Thu Nov 28, 2019 7:03 pm
1.062, I believe.
Post by TRDxB2 » Thu Nov 28, 2019 7:22 pm
From previous authors 1.060 -1.062
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Nov 28, 2019 9:02 pm
Considering that good Hyatt’s are getting hard to find, I have considered making some over sized axle shafts. Probably at least.005 bigger
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Tue Dec 03, 2019 1:47 am
Hello Les,
That is a great idea. I have a few hundred good Hyatt bearings of varying measurements and at this time they have limited or specific applications. We could then juggle the bearings based on their specs, to match inside or outside placements. Also, if they were made longer as well.
Thank you for your willingness to take on these projects that offer such a valuable contribution to our hobby.
Ken Buhler
Work honestly
Stay true to your word
Get the job done right
Kerry
Last Name: van Ekeren
Post by Kerry » Tue Dec 03, 2019 2:25 am
Rather than trash an axle that could still have some life left, what about an over size bearing sleeve, that would be much cheaper I'm sure. :D
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Dec 03, 2019 8:11 pm
I’ll let Kerry solve it with the modified sleeves. I sure don’t need another project!!
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Tue Dec 03, 2019 8:20 pm
Thanks for the replies ! :D
I have the books now, but the one spec sheet is much handier 8-)
I measured 1.060 on my only Hyatt location, the right inner of my Ruckstell.
The bearing measures .497-.498, most on the larger side and smooth and even.
Have early safety hubs and bearings on the outer locations.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Tue Dec 24, 2019 9:58 am
In Chaffin's axle book, he mentions using shim stock around bearing sleeves when the axle housing bore is oversized. It occurred to me that this could work to reduce the sleeve diameter to fit an undersized Hyatt bearing in a standard-bore axle housing. Have any of you tried this?
I have not mic'd my bearings yet but I know that I don't want to get solid roller bearings. I am leaning toward using the modern bearings but shimming is interesting to me.
Post by Scott_Conger » Tue Dec 24, 2019 11:01 am
Shim stock works just fine
Post by Jerry VanOoteghem » Tue Dec 24, 2019 4:39 pm
The problem with altering sleeve thickness, axle diameter & adding shim to compensate for worn Hyatt bearings, is that Hyatt rollers do NOT wear evenly, without taper. When using a tapered roller, because of the differing circumference of each end, one end will tend to "skid" on the axle & sleeve and cause premature wear. The different circumferences will also tend to skew the roller to the drive shaft, which will twist the Hyatt cage and cause further accelerated wear. If you want to do any of the above alterations, it should also be coupled with Hyatt rollers that have been centerless ground to a consistent diameter.
