Rear axle fixture
RodellJunior
Last Name: Rodell
Rear axle fixture
Post by RodellJunior » Sun Dec 01, 2019 4:55 pm
I'm sure this topic has been covered before. I am looking for drawings/ideas to build a fixture to set up the rear axle and driveshaft assembly.
Is there something in the Ford Service bulletins? Thank you for your help, Jim.
Eck
First Name: William
Last Name: Sheppard
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster pickup
Re: Rear axle fixture
Post by Eck » Sun Dec 01, 2019 6:38 pm
I used the jawhorse and fixture to overhaul mine and it worked very well, was steady and stored well when finished,
Last Name: Hjortnaes
Post by DHort » Sun Dec 01, 2019 7:12 pm
Mine is similar. The opening is 3" x 7".
Post by Mark Gregush » Sun Dec 01, 2019 7:17 pm
Mine is different but the same. Bigger opening where the pumpkin sits.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sun Dec 01, 2019 7:47 pm
Jim, The Ford Service Bulletins do have plans for a rear axle and drive shaft assembly stand that is made from 2x4's. Vol 1 pg 78 if someone can post it.
Post by TRDxB2 » Sun Dec 01, 2019 8:17 pm
Bought a 8ft 2x6, cut in half and biscuit joined the halves and did the cut out, set on power miter-box stand- with clamps, easy to store.
Setup an old axle for peening. Threaded rod for pressing in the bushing - wrapped some cardboard around the rod o keep it centered in the new busing and used an old one to to clear ball cap end. Only intending o do just one.
Post by Steve Jelf » Sun Dec 01, 2019 11:44 pm
I dislike the one from the service bulletin. It's a space waster.
Here's what I use. It's made from scrap lumber. I think I may have spent $2 on hardware.
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Post by Steve Hughes » Mon Dec 02, 2019 1:08 am
Looks like you borrowed the seat from a one holer there Steve. Bet it works great.
