TT rims
Topic author - Posts: 88
- First Name: Rod
- Last Name: Petrie
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
TT rims
I bought these 20" rims to replace my rusted out ones but they are different. Do I need to add something or modify them for the valve stem? I don't think the valve stem should just stick up through the oval hole in the rim
- First Name: Justin
- Last Name: H
- * REQUIRED* Type and Year of Model Ts owned: 1924 TT C cab
Re: TT rims
The boss around your old valve stem sat in a keeper in your felloe to prevent the rim from spinning on it. Your new rims don't appear to be TT but should work okay as long as everything fits up as stock. You should weld in a similar boss on the new rims to act in the same manner as the originals.
Justin in Western PA
