21" tires for a driver
Topic author - Posts: 147
- First Name: Roger
- Last Name: Harmon
Which are more highly recommend, Lucas (from Snyder's) or Universal brand?
Re: 21" tires for a driver
Just installed a set of the lower cost Universal 4.50/4.75 x 21" on my touring. Like the tread pattern, and edge, they ride nice too. Nothing like new tires....the old ones were 12 years old harder rubber
Check on line, you might find better prices.
https://www.lucasclassictires.com/21-Tires_c46.htm
If you look sometimes you can find free shipping. I am not recommending any particular brand, all my tires are used, some almost new but older.
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
just until tomorrow...
https://www.mtfca.com/phpBB3/viewtopic.php?f=16&t=8755
Coker tires Black Friday special.
- First Name: Adam
- Last Name: Doleshal
The Universal 4.50-4.75x21 tires are the cheapest, and slightly fatter than the “stock” tire. Universal has free shipping on everything thru this afternoon. Its a once-per-year deal they only do on the four days after Thanksgiving. Free shipping should save you an additional $80 or more.
Clincher tires are famously all made in the same factory and vary only by name, tread pattern, and price, with no variation in quality. How about 21" tires? Does the same hold true for them?
- First Name: Dennis
- Last Name: Prince
If you hate changing tires as much as I do, I would step up and get Firestones. They will last a whole lot longer, also don't forget to check you toe in when you put the new tires on.
Steve - most but not all 21" 's are U.S. made.
- First Name: Brian
- Last Name: Mettling
- * REQUIRED* Type and Year of Model Ts owned: 1922 touring, 1933 Dodge
I’ve had those Lucas 21s on my T for about 7 years now. I like em. Only compliant is that they turn brown after a few hours of UV exposure outside. I thought they were all made in Vietnam though, not USA
Lucas 21" are imported - 21" Firestone, Goodyear, Goodrich & some others are made in the U.S.A.
- Last Name: Patrick
I bought a set of five (5) 21” Universal tires for my 1926 Coupe, 48 years ago in 1971. While the treads are worn, the rubber is still good and handle the car nicely and I would highly recommend Universal tires, however, because of the close friendship between Henry Ford and Harvey Firestone and their historical link, 2 years ago, I bought a new set of five 21” Firestone tires from Snyder’s, but haven’t gotten around to mounting them yet. Jim Patrick
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
I bought new Universal 21"s this spring and they were made in Vietnam.
- First Name: Dale
- Last Name: Myers
Here is a link to an earlier discussion about 21" tires.
http://www.mtfca.com/discus/messages/708324/722284.html
The old forums are a gold mine of information.
- First Name: Reuben
- Last Name: Kugel
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1926 RAJO Speedster
Whatever tires you decide to buy, check out Summit Racing. All orders over $100 is free shipping all the time. Yes they do carry a number of tires for Ts. Got two sets of Universals (plus flaps and tubes) from them the last couple of years.
1915 Touring
1926 RAJO Speedster
1926 RAJO Speedster
If Summit's website lists any Model T tires, it's designed to keep them well hidden. I entered Model T Ford for 1915 and 1926, and got several pages, mostly showing car covers.
- Last Name: Clements
Steve, Search for tube by size, then options will appear for tires. That is how I found them.
- First Name: Henry
- Last Name: Petrino
"The best way is always the simplest. The attics of the world are cluttered up with complicated failures. Henry Ford
Don’t find fault, find a remedy; anybody can complain. Henry Ford"
Very true, Dan. William of Ockham (1285-1347/49) stated a principle referred to as Ockham's Razor that, in modern terms, says all things equal the simple answer is usually the right answer. It's still true!
So Summit has at least one tire for Model T. Its the same price as Coker's, so Summit's free shipping makes it a good deal.
- First Name: Don
- Last Name: Allen
That's where I bought mine. I lucked out and just happened to look them up when they were having a 10% off sale on tires. That, added to their free shipping on orders over $100, made it a nice deal.
1924 Touring
- Last Name: Hand
Coker site shows several 21" tires, the least expensive listed is Coker Universal Economy Model A Tires 78705 at $112.00 each, look up 21" for a Model A, many reply's here addressed referenced 30" Cinchers
- Last Name: Jablonski
I am more than pleased with the 21" Lester's I just put on my car. The tread is siped for better traction and overall gives a more comfortable ride.
