Steering column
dmdeaton
Topic author - Posts: 732
- First Name: Danny
- Last Name: Deaton
Steering column
I stripped out a later model column today mainly for the sheet metal column. I have a saw cut brass quadrant and gear case I am thinking of dissecting and using for my speedster column. Will the new 5/1 shaft and gears work with this combo? I have read that the new stuff is tight in the older brass gearbox?
Re: Steering column
I think the older brass cases didn’t have the routed out section of the case to use the oversteering stop pin the later ones did. I haven’t tried to make the change over but earlier forum posts have some not having much fit up trouble and others having to use timesaver compound to fit the gears better in the case. Maybe someone on the forum.has the earlier brass case and used the new set up in it with no trouble and without the oversteering pin it it. There have several earlier threads about doing it.
dmdeaton
- First Name: Danny
- Last Name: Deaton
Re: Steering column
I found this last thread answering Some of my questions
https://www.mtfca.com/phpBB3/viewtopic. ... umn#p63541
dmdeaton
- First Name: Danny
- Last Name: Deaton
Re: Steering column
The brass case I have does not have the routed out overtravel groove. I have no clue what year it is. I will take some picks
Jack Putnam, in Ohio
- First Name: Jack
- Last Name: Putnam
Re: Steering column
When fitting new gears and shaft in an original case I prefer to use valve grinding compound to remove any high spots on tight fitting gears. I assemble the components of the steering column dry on the bench and then put a generous amount of grinding compound to the gears themselves. Then rotate the shaft until it turns freely. Once grinding is complete, remove the parts and wash out all grinding compound and reassemble with grease. IMO timesaver will not cut as needed and is not worth the effort to get a good fitting gear case.
Re: Steering column
Well, it looks like someone cut up a very early pre-'15 column
I can almost guarantee that someone would trade you a working, complete steering column for that quadrant and steering case.
dmdeaton
- First Name: Danny
- Last Name: Deaton
Re: Steering column
Scott
I am building a somewhat brass race car replica. I am trying to keep with the brass as much as I can.
- Last Name: House
Re: Steering column
.....yet another frankenstein T.....
Re: Steering column
Blame these guys....
Dropacent
- Last Name: Morsher
Not nice
That’s not a very nice thing to say, George. Back in the teens and twenty’s there were thousands of Bugs , put together lovingly by young men desperate to have an automobile, and I’d guess most if not all were very proud of them. Assembled with whatever they could get their hands on. I have an ancestor that was known to have the fastest Bug in southern Lorain county! People can assemble these things today and be very era correct, and I sure don’t think they are frankensteins, and in fact, some can be worth much more than a stock T, and IMHO , more fun to look at.
- Last Name: House
Re: Steering column
That’s fine Tim...”not a very nice thing to say”....and my opinion is that cutting the sheet metal column of a pre 1915 T is not a very nice thing to do - especially when the bling bling is to be grafted onto a ‘New and Improved’ square flange steering tube.
Dropacent
Steering column
I’m not here to defend Danny. I did , however , re-read his post and he doesn’t say he cut the early column, and he doesn’t say he’s using a square column base. If those prejudgements make you feel better, then fine. I know Danny and he’s a nice young man very interested in Ts and will do something very nice with his project. Sounds to me like he’s doing just what a young feller in the old days would do. I’m in the club of “when you own it, you can do whatever you want with it” I just sold an early gear case and quadrant, without any care of what the new owner was going to do with it. I’ll leave the policing to the Correct Police !
dmdeaton
- First Name: Danny
- Last Name: Deaton
Re: Steering column
So George, the brass quadrant will not fit on the later column? I haven’t tried it yet.
And yes, I bought the quadrant cut. I’m sharing my build frame up with the guys on the vintage ford forum with nothing but good comments. I built a fordor model A old school hot rod from the frame up old school. I have a sweet stock restored 31 deluxe roadster. This is a learning curve starting a model t build, and yes I am building what interests me at the moment. Maybe next a nice stock t? Who knows. I like them all.
Re: Steering column
I have restored and enjoyed several speedsters over the years. More than most, I try to keep the speedsters I have really close to correct for the years they represent. Personally, I prefer for them to have a quality (or lack thereof?) that they would have likely had back in their day (not the worst end of quality, but not over-restored either). But that is me.
If you are trying to make the car "era correct", then using the early gear-case would be the proper way to go. However, if your intention is to build a "brass era" speedster in the modern sense, where later engine and rear end, under axle wishbone, demountable (or even '20s style wire) wheels are used? I would recommend not using the early style gear-case. For a couple different reasons. One being safety. the early riveted together gear-case can and sometimes does shear, suddenly leaving the car without steering. Yes that is a rare occurrence. But speedsters being driven faster and harder than most brass era cars increases that risk considerably. IF (my big IF again) most of the car is not going to be "era correct", it is foolhardy to used a gear-case that adds that risk. IF you are going to make and keep it "era correct, then, even though most people will not know the difference, just knowing your car is that correct is worth the added risk. Besides, if you treat the car as a "brass era antique"? You probably won't push it that hard either.
The other reason to not use it, closely related, is that such a rare and desirable part should maybe be kept aside to use on a "proper" brass era car. The also closely related flip side of that coin is that if you are making the car "era correct"? That piece does in fact belong on the car.
As an aside comment. There is really nothing at all wrong with building a brass speedster, using a bunch of reproduction brass bling, repro hood and fenders, modern repro body kit, a mostly '20s chassis and wheels etc etc etc. Such cars can look great, and be a lot of fun! I love tours and endurance runs with a bunch of cars like that participating. They look and sound wonderful running down the back roads. It just becomes pointless to use a rare and valuable part on such a car
tdump
- First Name: Mack
- Last Name: Cole
Re: Steering column
A short cut to having a brass quadrent is to use a newer style that was nickle plated and polish the nickle off.That is what I did on my pickup project steering.
Corey Walker
- First Name: Corey
- Last Name: Walker
Re: Steering column
Along the lines of what Wayne said, I’ve got this column with a later one piece gear box and reproduction brass quadrant that I’m going to use on a speedster. You can tell it doesn’t belong together but it’s similar and nobody but T people will know. I had it in my 1914 until I found an original column for it.
- First Name: Henry
- Last Name: Lee
Re: Steering column
It really follows the rules of "To each their own". As Mother use to say, "If you do not have something nice to say, say nothing at all". I applaud anyone willing to build a Model T from nothing of missed match parts etc. Why? Simple, it shows the person is interested in the full assembly and create their own interpretation of a Speedster. I have been criticized beyond words that are inappropriate on this forum for doing just that stated above.
I told others as I am going to say here, "Fine, you buy up all those parts that you say are rare, store them in a big warehouse or whatever and supply the needs to keep them all going at a reasonable price". They shut up real quick. Don't judge unless you are willing to be judged. People whom powder coat wheels on an award winning car. How? It is not original paint, it is charged plastic dust is a perfect example.
The Model T hobby as we all know is losing interest at a rate years back no one saw coming. If, a person is willing to build one up from parts and shows interest in a one of a kind car, support it. Do not be so critical as you will send that person away. Grumpy old men in set ways I respect, Grumpy old men pissing people off I have no love for nor time. There is not enough parts around by the critic's standards to build original cars. I say this as well, always reach out to help a person in need is a future friend indeed. Hey, it sounds corny like Casper the Friendly Ghost, but it is the truth. We must all do our part and remind ourselves time to time we are a club that requires mentorship in trust, support, friendship, and even in the times of change accept certain things to keep the interest alive.
I have this smile on my face because of a new outlook on life and new friends here I have found from mutual respect and interest.
All the Very Best to All!
Hank in Tin-A-See
Hank in Tin-A-See
tdump
- First Name: Mack
- Last Name: Cole
Re: Steering column
Good way to put it Henry.
There are some folks out there,that will wait 3 years to find the "correct" bolts for the running boards of a 1911.I know,I overheard the guy say it at a meeting. 3 years,he could have had his car much further along assembly wise,and simply go back later and swap the dang bolts!
I want to drive the da-- thing before I kill over.not spend my last days scratching thru the internet for a certian correct for the 3rd of June 1923 horn button mounting screw.
autoneer
- Last Name: Beaumont
- * REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout: 1913 Canadian touring: 1921 Pickup
Re: Steering column
I have used later gear sets in earlier columns, to gain better steering, as I drive my cars. The earlier brass riveted gearboxes have deeper cut internal gears, and the later gears will not drop in. Get a later case that they will, measure the ID across opposing gear teeth, and turn out the few thousandths of the earlier gear case in a lathe to match, then do the fine valve lapping trick mentioned earlier in this post to finish up. It will make a much better & safer steering car, and no one will be any the wiser, being as none of it is externally visible.
Speaking of Franken-T's, I bought this little pickup inexpensively from the widow of an old friend, somewhat disassembled and missing a lot of stuff. It was overlooked at the estate sale, being up on blocks and missing its wheels, among a bunch of other stuff. It was originally a Fordor sedan that was very nicely made into a closed cab PU certainly sometime before I was born, probably because Ford never sold a closed cab PU in the model T era. It once belonged to Dennis Day of the Jack Benny show. Chassis is 1921, body 1926, that's the original Fawn Gray color matched from inside a door. I am working on a stock looking steel PU box for it now, which will further confuse the experts, but its the only PU I own, so it makes regular runs to the dump, among other errands. It has the later steering gears too. Good luck with your project, Danny. Jeff Beaumont, Gardnerville, NV
Re: Steering column
Danny, your brass steering box and quadrant look to be really nice. The riveted case looks to be tight, the quadrant is tidy and the riveting in the steel tube looks tight.
With all this looking so good, I would not disturb any of it. Rather, I would cut your later metal tube and weld it to the reminder of the tube still in the brass parts. There is enough variation in the cross section of the tubes that a good fit of the brass bits in a later tube may well be quite difficult to achieve. Welding two steel tubes offers a much easier solution, and one which will be easier to manipulte to achieve a good looking result.
Hope this helps.
Hope this helps.
dmdeaton
- First Name: Danny
- Last Name: Deaton
Re: Steering column
I think I will use the later gearbox I have and just restore it. Not because the rarity of the brass one I have. Because I have it cleaned up and stripped it down. New rods for it. Quadrant is pretty rough. Might source one and then I will be good. Didn’t mean to start this mess.
- Last Name: House
Re: Steering column
Well, good for you Danny. And build that speedster. Please consider returning the brass quadrant and steering gear box to the restorer’s pipeline. In your initial post I read that you disassembled a later steering column for the sheet metal column ‘tube’. I suppose there might be a good reason to hacksaw the very early column. I just can’t think of one. To those I offended by wrongly assuming it was cut to be grafted; I profusely apologize.
tdump
- First Name: Mack
- Last Name: Cole
Re: Steering column
From the looks of that brass quadrent,it appears a scrapper got ahold of a car and removed that brass with his sawsall and someone caught it at the yard before it got gone to the smelter. I make rounds to a couple yards like that and found the shaw tractor conversion rearend I have and a couple other peices that woulda been lost.
dmdeaton
- First Name: Danny
- Last Name: Deaton
Re: Steering column
The cut column was just a purchase, I didn’t cut
Im just gathering parts and thinking out loud
Here are a couple I took pics of this morning.
Re: Steering column
No worries Danny D ! Those of us paying attention here already know that you didn't cut that early column. The fact is, probably hundreds of such columns were cut that way over the many decades before these parts became a bit more expensive and rare. Most by people that wanted to save the most valuable bit (whether for scrap brass or the smaller end worth five bucks without having to handle the longer bulk that only added a few more dollars back then). I have probably seen nearly a dozen such cut early gear-cases with a couple inches of steel tube.
As for the "nit-pick-bickering"? Try to not let it bother you. There are several regulars on this site that seem unable to keep out of that stuff. Personally, I try to stay out of it (most of the time), however, I do sometimes mange to start it without intending to.
By the way, although I do not know him personally, George H is also a fine fellow that helps others online often.
We look forward to hopefully many updates on your progress, pictures of the car as it goes together, etc. We are funny that way. And then, hopefully in a year to two, having you along on tours with local or major clubs! Tours and the comradery is some of the best fun of a model T!
dmdeaton
- First Name: Danny
- Last Name: Deaton
Re: Steering column
All is good. I will share the build as I go along.
Thanks all
Thanks all
