Old photo- Model T truck
Topic author - Posts: 1703
- First Name: Herb
- Last Name: Iffrig
Is it a 1916?
- Last Name: Jorgensen
Re: Old photo- Model T truck
Interesting place to mount the tail lamp.
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
- First Name: Michael
- Last Name: Royster
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout 1916 Runabout
1916 I do believe.
Looks like a "hearse hauler" !
I would suggest it is a 1915 from the horn bulb mounted inside. The radiator even may have black paint on it. Wouldn't '16 have a horn button on the steering column? Also an early sign is the side lamp fount.
No chains are visible so it appears to be a shaft drive conversion. Demountable wheels look plenty Beefy.
It is quite different in many was to the T truck I have seen from that era.
I have most of the sheet metal for a 20's roadster and have thought about doing something like that with the top, only shorter on my 21 huckster.
