Un-marked speedometer drive
Topic author - Posts: 5414
I got this speedometer drive. The only marking I can find are Pat Pend, part of the numbers 1/2X1(2-1/2X1) and maybe a date 4 23. it was mounted on a T spindle with Stewart mounts. Any idea who made it? Turns about the same in both directions,.
Re: Un-marked speedometer drive
Looks like one Don Marr made back in the early '60s.
Thank you Larry, that is a start. It did have the Stewart chain drive end mounted, so at least I know Stewart cable will fit.
