headlights with additional bulb question
Topic author - Posts: 18
- Last Name: Sears
- * REQUIRED* Type and Year of Model Ts owned: 1924 Roadster
I have a 24 roadster that has a set of headlights with a bulb on top of the reflector and a single wire running between them and up to the terminal block (disconnected). This is in addition to the high and low beam bulb.
I haven't been able to find any documentation about this setup.
Can someone tell me what this light is for and what to wire it to?
Re: headlights with additional bulb question
Dan Treace,Sept 08, 2017 said:
"Those are typical '19-'20 lamps on the first Fords with electric start. Mostly seen on sedans as they got electric first."
"The double bulb don't have adj. screw."
http://www.mtfca.com/discus/messages/70 ... 1504883400
I hope this is what you are talking about.
- Last Name: Sears
Not quite Dan,
Maybe this picture will help
- First Name: Michael
- Last Name: Deichmann
In modern times these reflectors are rather atrractive as they allows you to make your headlight more compliant with current regulations.
Ford Model T 1914 Touring
- Last Name: Sears
You are right Rich.
To what do I connect the top bulb?
Low or high beam or does it matter?
- Last Name: Golden
Some Model As had that small bulb for a parking light.
The reflectors may be Model A reflectors.
I have never measured the model A lights to see if they are the same size.
I don't see any information. I would assume a separate wire was included in the wiring harness for these lights and a separate switch. I too have some of these lights and reflectors. Perhaps those cars had a light switch with a third position.
The set of these lights I've seen a number of years ago had a rather complicated socket/wiring & keeper assembly.
- Last Name: Stephens-Marcle
While it is true the model A has a SIMILAR set up as the T , however, they are not interchangeable......I know , because I tried this with a wonderful pair I bought from Dan Treace a couple years ago at Lurray swap meet. respectfully, John
- Last Name: Dewey
Model A reflectors are very different; for one thing, they clip into the headlight bucket and are not spring loaded like the T ones. These are fairly uncomon, not being used very long. The upper bulb is actually a parking lamp bulb, but could be used (I suppose) as a "Low beam" bulb.
T'ake care,
David Dewey
David Dewey
