Another odd early carburetor part, what is this ?
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Sat Mar 14, 2020 9:59 am
Just going through the box of carburetor parts and also found this one, any ideas? Bob
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Re: Another odd early carburetor part, what is this ?
Post by got10carz » Sat Mar 14, 2020 10:07 am
Is that the piece for a late 31 Zenith?
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sat Mar 14, 2020 10:29 am
One of my banjos. 😀
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Sat Mar 14, 2020 10:31 am
Its part of a gas inlet fitting. Its missing the hollow bolt that fits thru the two large holes and screws into the gas inlet of the carburetor.. There will be a gasket on each side of the part at the large holes to seal the hollow bolt. This part swivels to any position to make hooking up the gas line easier to hook up. Some model As and many accessory carbs used this style of fitting.
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Sat Mar 14, 2020 11:31 am
It is a Stromberg fuel inlet. It mounts to the bottom of many of the larger M and O series carburetors with a through bolt. Originally it would have a cone shaped fuel screen inside.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Mar 14, 2020 11:41 am
I would guess it’s the fuel inlet off a Winfield carburetor or similar.
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Sat Mar 14, 2020 12:01 pm
It is not for a Winfield.
It is what is commonly called a banjo fitting for a Stromberg O, L or M series carburetor.
www.strombergof.com
I'm well over 1000 Stromberg rebuilds, this fitting is part of the conversion to modern needle and seat that I make for Stromberg O, L, M series carburetors that do not use the later style inlet.
But whatever.....
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Sat Mar 14, 2020 3:26 pm
It's a novel approach. No gaskets!
A spare Stromberg M-3 here.
Poop, can't post pics today I guess...
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Sat Mar 14, 2020 3:29 pm
Try again.
