Scat stroker rod inside diameter?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Mar 17, 2020 7:52 pm
I want to use a set of Scat stroker rod shells. They fit a 1.5” crank pin. I’m trying to find out what is the correct rod big end inside diameter?
Doing some careful measurements, I’m guessing that it is 1.610”. But I REALLY hate guessing at something like this!!
Does anyone have a set of these rods not installed and could tell me the answer?
I suppose I can phone Scat and hopefully they will tell me. The shell manufacturers website is not helpful
First Name: Henry
Last Name: Lee
Re: Scat stroker rod inside diameter?
Post by Henry K. Lee » Tue Mar 17, 2020 9:49 pm
Skat will grind to your specs on the rod journals and mains for a small fee. They did a couple of odd balls for me.
Hank
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Post by tman1913 » Wed Mar 18, 2020 2:00 pm
Less
I get 1.625” bore on a stroker Scat rod for inserts.
Still maybe be best to call Scat or King bearings
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Mar 18, 2020 2:09 pm
Mike
Thank you for the information. I have emailed Scat for the information, so far nothing.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Mar 18, 2020 2:47 pm
You can babbitt them too. I babbitted these for a customer last year. They are now in a OHC Fronty.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Mar 18, 2020 4:27 pm
Guys
Thank you for your input. I just got off the phone with Austin at Scat and there specified size is 1.6249”!! So the 1.625 is pretty darn correct!! We will be honing these on a rod resizing machine so now have a great target size!
I am installing this in a set of Townsend aluminum rods on a crank with 1.5” crank pins that is stock T stroke. So using Scat or A rods is not a good option (need the 7” C-C).
I appreciate your input
