Chassis paint question
Topic author - Posts: 193
- First Name: Marty
- Last Name: Bufalini
I did a forum search with no luck. I think there was a thread about chassis paint. From what I remember, it was a brush on paint that would not show brush marks and was hard as nails.
Can anyone point me in the right direction?
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
- First Name: Terry & Sharon
- Last Name: Miller
Re: Chassis paint question
You also have POR 15, and Chassis Saver. I have used both of these and can recommend either but I like the Chassis Saver more. It's thicker paint
Good Luck,
Terry
Good Luck,
Terry
- First Name: Marty
Gentlemen, Thank you!
- First Name: fore
- Last Name: door
- * REQUIRED* Type and Year of Model Ts owned: 1922 centerdoor 1927 fordor 1916 centerdoor
Marty, I use Automotive Grey Rustbullet for the primer and Blackshell Rustbullet for the black finish. Its as close to powder coating as you can get. It can be ordered thru www.rustbullet.com.
- Last Name: Miller
Thought must be taken as to the rustproofing put on a frame.
It must be high quality to last, to adhere, and to prevent rust. A very important consideration: Seeing cracks, should they develop, BEFORE they grow to failure.
Powder coating is great in a lot of places but cracks can develop under the powder coat and not be visible until it's too late. I considered spray on truck bed liner. Same disadvantage. A good quality rust paint is the answer I believe. Your mileage may vary and I respect your choices. I'm just trying to enlighten my Model T buddies.
Good Luck,
Terry
Good Luck,
Terry
- Last Name: Gould
I used brush on POR 15 reluctantly because I thought the brush marks would show. They don't. I was very impressed. I used a quality bristle brush on a sanded but not sandblasted frame if that makes a difference. In the past I've sprayed DP 90 epoxy primer, but this POR 15 has that beat hands down.
While Rustolium does not stay shinny that is what I used. Has held up just fine for over 15 years. Wire bushed the frame, used Rustolium rusty metal primer and black over that.
I like Van Sickle enamel. https://www.vansicklepaint.com/ It flows on well and is fairly durable. It is inexpensive compared to many paints. It does dry slow and does not have a high gloss but an original look to my eyes. I use Por 15 for inside panels as it has poor UV resistance. Rustolium is also nice but slow drying. The slow drying lets the brush marks flow out.
- First Name: Marty
Great suggestions! Now I gotta do my homework!!
Thanks!
Thanks!
I've always used gloss black Rustoleum on all my cars. I spray it on. In fact, it's the first thing I do before I start assembling the car. Be sure to weld up any non original holes in the frame before painting.
- Last Name: Rogers
Mark Gregush wrote: ↑Thu Mar 19, 2020 12:52 pmWhile Rustolium does not stay shinny that is what I used. Has held up just fine for over 15 years. Wire bushed the frame, used Rustolium rusty metal primer and black over that.
