Wind wings
Russ T Fender
Topic author - Posts: 467
- First Name: Val
- Last Name: Soupios
Wind wings
Does anyone have the dimensions for the glass? I guess I can fudge it but I'd rather get it right! Thanks.
Dropacent
- Last Name: Morsher
Re: Wind wings
Val, I think jack Putnam, bluffton Ohio has it. Good luck, great accessory
Re: Wind wings
While no glass dimensions are given in the Service Bulletin, you might get close to extrapolate them from the sketch and measures of the clamp placements.
Re: Wind wings
This new 1926 touring has the wind wings fitted, photo may help too.
Russ T Fender
- First Name: Val
Re: Wind wings
Thanks for the information. I think I have a template on the way!
Ruxstel24
- Last Name: Hanlon
Re: Wind wings
Say something if you don’t get a template Val.
I’ll go and measure mine and let you know if you need.
I believe my neighbor cut the glass, he might have a copy ?
Mustang1964s
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Re: Wind wings
Russ,
Please post a picture and the dimensions when you get the template.
I would love to put a set of Wind Wings on my wife's cars.
Russ T Fender
- First Name: Val
Re: Wind wings
Steve, here is the template I received. I don't have access to my car right now so I can't hold it in place to see how it looks but it seems to be very close to the glass pictured in the Ford brochure posted earlier in this thread. The bottom of the glass is somewhat rounded on the template but I would probably make it parallel with the top. Hope this helps.
Russ T Fender
- First Name: Val
Re: Wind wings
Let me try that again!
Roffe
- First Name: Rolf
- Last Name: Oehman
Re: Wind wings
Hi. Took some pictures of my 26 roadster. Seems the sides are parallel sideways and up-down. 200mm X 440mm.
