On the road again
Topic author - Posts: 329
- First Name: Tommy
- Last Name: Coffey
- * REQUIRED* Type and Year of Model Ts owned: '21 Touring
On the road again
I got the new valves in our '21 Touring and got the manifolds to stop leaking, after having them off and back on three times. Today I cleaned the plugs and the New-Day timer and it runs good again. I first thought maybe I should have set the valves a little closer but now that I fixed the exhaust leak it sounds ok, probably will be fine once I set the hood back on.
Re: On the road again
Good for you, Thom
