U&J Carb adjustment initial setting
Topic author - Posts: 667
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
I have four rebuilt U&J carbs to test run and am looking for advice on the initial adjustment setting. I've heard everything from 3/4 turns to 3 full turns.Can anyone who has run these carbs narrow down these numbers? Thanks : Bruce
- First Name: Rick
- Last Name: Duquette
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Re: U&J Carb adjustment initial setting
Bruce, I have copies of the U&J installation, adjustment and starting instructions. The adjustment instruction says the screw at the bottom of the carb should be opened three-quarters of a turn. Instructions also recommend to "set the throttle one-third open, the dash control rod three quarters up and turn on the switch. Hold the air choke tight past two compressions as the motor is turned over, then release choke on the third compression stroke the motor should start." Hope this helps.
- First Name: Bruce
Thanks Rick; That's exactly what I was looking for. Bruce
