From what I've read the correct speedometer head for my July '13 Touring would be a Stewart and Clark Model C.
Is the head marked Model C anywhere?
I've seen a number of the earlier Model 26 heads but have not seen a Model C up close.
Thank you,
Gene
1913 Stewart and Clark Model C Speedometer
Topic author - Posts: 339
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
Gene Emering
Newton, New Jersey
Newton, New Jersey
Re: 1913 Stewart and Clark Model C Speedometer
I'm not sure this answers your question or not.
Russ Furstnow on Thursday, February 03, 2011 "we know this is an early Model C because of the Stewart and Clark designation on the dial face"
http://www.mtfca.com/discus/messages/179374/187778.html
My apologies if you have already seen these. This might be of some help too.
http://www.mtfca.com/discus/messages/17 ... 1306158018
https://forums.aaca.org/topic/239479-st ... rk-speedo/
I don't think the Stewart & Clark model C would have been used as late as July. By then they should be Stewart Warner. There are some slight differences, like red being used on the dial, but I would use what you have.
- First Name: Gene
Thank you Rich and Larry.
Gene Emering
Newton, New Jersey
Newton, New Jersey
