How do you remove steering case brass rivets?
I drilled out the quadrant rivets but when I tried to bang out the brass case rivets they did not budge. And I am afraid of ruining it.
I want to replace the steel levers with brass levers.
Thank you for your help!
How do you remove brass steering case brass rivets?
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
Re: How do you remove brass steering case brass rivets?
There is a good article with pictures on Royce’s Model T Fix site. Art
I believe that the case pieces & rivets are all soldered together.
Topic author - Posts: 183
- Last Name: Poane
- * REQUIRED* Type and Year of Model Ts owned: 1916 Hack, 1910 Touring, 1914 Touring, currently a Touring 1912, 1912 Torpedo Roadster
Perfect, thanks!
