coil box wire
TBones12
Last Name: Poane
* REQUIRED* Type and Year of Model Ts owned: 1916 Hack, 1910 Touring, 1914 Touring, currently a Touring 1912, 1912 Torpedo Roadster
coil box wire
Post by TBones12 » Sat May 02, 2020 6:48 am
Any suggestions as to where to get wire to wire up a coil box?
Craft stores are closed so can't get a spool of craft wire.
The coil box I restored last time had about a three strand braided copper (26 ga?) wire.
I was going to try and strip whatever wire that is in my basement.
Does it have to be brass?
I wouldn't think so?
What do you use?
This a 12 box.
Thank you in advanced.
Bob
TBones12
Last Name: Poane
Re: coil box wire
Post by TBones12 » Sat May 02, 2020 9:12 am
I figured it out. Got the right wire.
JohnM
Last Name: Michaelree
Board Member Since: 2010
Re: coil box wire
Post by JohnM » Sat May 02, 2020 6:27 pm
In a pinch, you can split and use one side of a lamp cord.
Re: coil box wire
Post by TRDxB2 » Sat May 02, 2020 6:43 pm
Is this what you were looking for?
TBones12
Last Name: Poane
Re: coil box wire
Post by TBones12 » Sat May 02, 2020 7:51 pm
Thank you!
