Lettered pedal differences
Don ellis
Topic author - Posts: 384
- First Name: Don
- Last Name: Ellis
[image][/image]looking through my spare parts I noticed the difference in the style of the letter in this reverse pedal. I probably would have never thought about it I hadn’t had them lying next to each other. Does anyone know anything about the reason or is it just different manufacturers?
Re: Lettered pearl differences
The one on the right is peculiar - is there a cartouche on either ? DB, TW ?
Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
Are there any differences at the other end?
This is what you can buy today to weld on. It looks a little like the one on the right to me.
I would suspect molds changed back then as well as today.
Don ellis
- First Name: Don
- Last Name: Ellis
Re: Lettered pedal differences
Well I see spellcheck got me again. One of these days I’ll learn to proofread.
I’m working at the fire station tonight, tomorrow I’ll check for makers marks.
Don ellis
- First Name: Don
- Last Name: Ellis
One is marked DB, the other just a part number.
This is the DB
I have an interesting one on my '13 roadster. The pyramid pattern on the clutch pedal is coarser than the other two pedals. I assume it's from the time when Ford was changing over from Dodge Bros. to his own production methods?
nsbrassnut
- Last Name: Lee
Here is one from Canada. RHD reverse pedal on my '15.
Marked DS, believed to stand for Dominion Stamping in Windsor, Ontario which started to make parts for Canadian Fords about 193/14
Drive Safe
Jeff
Drive Safe
Jeff
