1912 DB front axle markings
Topic author - Posts: 223
- First Name: Michael
- Last Name: Abbott
- * REQUIRED* Type and Year of Model Ts owned: 1912 C-Cab
Hi,
Has anyone have any knowledge on the markings on a 1912 DB front axle. Were the markings on the four corners on this year only.
Appreciate any help on this
Michael A
Michael A
- Last Name: Eyre
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Re: 1912 DB front axle markings
From years of studying 12’s I believe the T 202 dB markings where towards the inside of the axle near the hump where the perch goes through. I probably can yet you a picture if you email me at meyre14t@yahoo.com. This may not be the only location.
- First Name: Keith
- Last Name: Townsend
Michael-
I believe the DB axles used during 1913-1914. Maybe late 1912?
My late 1911 has the Transue-Williams mark that is larger than the later years.
Keith
Keith
The DB markings were located in various place during 1912 and 1913. Many times they are on both sides, sometimes they are upside down. I've even seen them in four places on the same axle.
- Last Name: Abbott
That really helps, thank you
- Last Name: Abbott
Last question,
Would late 11 early 12 be the same as late 12 to early 13.
Michael A
Michael A
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
My late October 11 built car has T202 on all four corners. All also have db in a circle. The db on the left rear side of the axle is upside down. Art
- Last Name: Abbott
That really helps thanks Art.
