cherry picker arm length
dhosh
Topic author - Posts: 304
- First Name: Dennis
- Last Name: Hoshield
- * REQUIRED* Type and Year of Model Ts owned: '24 RPU (Raodster converted to Pickup)
Now that I have found a cracked break drum, I will need to pull the engine to get at it to do the rebuild.
Unfortunately, I am not at my car to take any measurements. I can look at a cherry picker tomorrow, to see if it will work for me. If it does, I can borrow it for a couple weeks. Does anyone have a measurement from the lift point on the motor, to the front of the car, so I can see if this lift's arm is long enough? It's a Pittsburg with foldable legs, I think, but other than that, I'll have to see i when I get there.
My grandson has a Jeep with a winch mounted on the front bumper... I thought about running it's cable to a 4" pully (rated at 3,000 lbs), attached to a steel beamed rafter. (Heavy steel building), as an option.
Thanks in advance....
'24 RPU
Petoskey, Mi
Petoskey, Mi
Russ T Fender
- First Name: Val
- Last Name: Soupios
Re: cherry picker arm length
I am assuming what you are referring to as a cherry picker is a portable engine hoist. Most engine hoists have an adjustable hoist arm that you can slide in or out depending on the weight of the engine. The further in the heavier load it can take On mine you can slide it all the way out for a T and that gives you plenty of clearance. I don't know what a Pittsburg looks like but I have never seen an engine hoist that would not work for a T, even the ones sold by Harbor Freight.
Russ, you triggered my brain cells putting 0 + 1 to come up with Pittsburgh as in Harbor Freight -- https://www..com/1-ton-capacity-foldable-shop-crane-61858.html
A model T engine -transmission unit balances somewhere between cylinders three and four. Variations for hogshead types, starter or not, engine head or not and other things.
I went down and measured my '15 runabout. Thirty inches full reach should be more than enough. Twenty-six inches would likely work. I have never seen a hoist made for automobile engines that cannot handle a model T engine. Although I did once use one helping a friend that the hoist was so cheap and small it almost didn't lift high enough (I had to give a half inch "Hoomph" to get it to clear the front cross member.
I have had a HF one for over fifteen years that does fine. I used it putting the engine into my '15.
Dan_Jensen
- First Name: Daniel
- Last Name: Jensen
[image][/image]
This worked for me twice. The legs on a Pittsburgh engine hoist will go under the front axle.
1923 Touring low radiator
Most engine hoists that are being talked about on this post have an extendable arm so the length shouldn’t be an issue. The one shown in the pic is almost identical to the Harbour freight version I bought a while back and probably made at the same place as others in this price range.
Summit Racing also has one for the same price. If there is a Summit Racing store near you
that would be great.
They sell lots of other Automotive supplies for just about everything.
dhosh
Very good,call... I think my friend's looks exactly like the one in TRDxb2 (?)'s post. It's arm is extended all the way... It just seemed short. I don't have the poster's name, but will check it's horizontal reach tomorrow.
By the sounds of everybody... Looks like it should work fine!
'24 RPU
Petoskey, Mi
Petoskey, Mi
The arm length is OK or adjust to your preference. The two legs roll up under the car so you can get directly over the engine and you can use a short chain with a hook to go through the eye bolt that’s screwed into the next to last spark plug hole. I think that’s where I screwed the eyebolt into on my last engine pull.
In my case I rolled the car backwards and lowered the engine. It just depends on your set up which way you do it.
dhosh
Yes... I've used them before... His arm was extended all the way out, but appeared too short... And I was there today, and forgot to measure it! Maybe tomorrow
'24 RPU
Petoskey, Mi
Petoskey, Mi
That picker will work - I have the same and have removed & installed dozens of T power plants with it.
dhosh
Very good, bro RojoRacer!
Thanks for the confirmation!
Dennis
Dennis
'24 RPU
Petoskey, Mi
Petoskey, Mi
OilyBill
- First Name: William
- Last Name: May
There was an article about 30 years ago, about how to remove a Model T engine, BY YOURSELF, WITH NO HOIST. The guy had pictures showing him tilting it up and over and out of the frame, resting it gently at each point so he could move to the new heaving point to continue the process. he not only took it out that way, but after he was done working on it, he put it back in by himself, by reversing the process!
But I'd rather have the hoist!
- Last Name: Hjortnaes
I never heard Bruce Banner owned a Model T.
