Front axle?
Wwbbim
First Name: Jace
Last Name: Jensen
* REQUIRED* Type and Year of Model Ts owned: 1922 Roadster
Front axle?
Post by Wwbbim » Fri May 22, 2020 4:48 pm
So I am confused about 4 different parts on my 1922 roadsters front axle. When I got the old parts, this is how it came assembled. I have redone the parts but am still co fused if they go like that? It is the parts that attach to the front axle spring(where it went when I got it) and attached to the actual axle.[image][image][/image][/image]
Last Name: Hatch
Re: Front axle?
Post by Dan Hatch » Fri May 22, 2020 4:56 pm
Where is the coil spring?
Wwbbim
First Name: Jace
Last Name: Jensen
Re: Front axle?
Post by Wwbbim » Fri May 22, 2020 4:59 pm
Re: Dan Hatch it was separated at the time we took the pictures
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Re: Front axle?
Post by Mustang1964s » Fri May 22, 2020 5:01 pm
Take a look at this thread.
http://www.mtfca.com/discus/messages/25 ... 1339967930
It shows some good close ups.
Wwbbim
First Name: Jace
Last Name: Jensen
Re: Front axle?
Post by Wwbbim » Fri May 22, 2020 5:04 pm
Thanks Mustang 64‘s that makes a lot more sense
Re: Front axle?
Post by TRDxB2 » Fri May 22, 2020 10:24 pm
Instructions and a caution. Be careful when installing the spring! If your not going to use the Hasslers you'll need to return the perches to their correct position. Bolts are available from for Lang's.
