Hi All
I am hoping somebody can please measure the internal distance between the two a pillar posts at the windscreen frame level. As per picture
Thank you
Andrew
27 Fordor windscreen post measurement
Tracer
Topic author - Posts: 127
- First Name: Andrew
- Last Name: Webb
- * REQUIRED* Type and Year of Model Ts owned: 1915 Towncar 1921 Centerdoor 1913 Racer 1927 Fordor 1927 Tudor 1926 Tudor 1927 Coupe 1926 Ute1926 Tourer 1915 Town Car
TMiller6
- First Name: Thomas
- Last Name: Miller
- Board Member Since: 2006
Re: 27 Fordor windscreen post measurement
I measured 40.38”. (102.5 cm) at that point on mine. It has Cubel replacement wood and is a ‘26. If that seems large, Remember there are two steel filler pieces that go between the frame and the posts.
Tom Miller
Tracer
- Last Name: Webb
Thanks Thomas
I think I will just have to work with fitting the windscreen frame to it
Cheers
Andrew
Cheers
Andrew
