Tool Time
Re: Tool Time
Post by Scott_Conger » Sun Jun 04, 2023 10:27 pm
I needed another pulley arrangement for a special carb part setup and I fortuitously found these pix of a Levin setup on eBay...it was even attached to an identical jackshaft that I have. Given that, how could I not copy it??...being that they make pretty much the best equipment in the world of its type, and I cannot spare the gelt for it, I decided to make my own...I think it turned out really well after I figured out how the original was built and worked. The dollar bill the fellow included in his 2 photos provided the scale I needed. I decided on miniature ball bearings for the idler wheels instead of bronze plain bearings. Just the barest of "tweeks" on the screws socks things down very solidly...it is very cleverly designed as I'd expect from a Levin product:
s-l500 (1).jpg (28.54 KiB) Viewed 40036 times
Here's my version:
First Name: craig
Last Name: leach
Re: Tool Time
Post by Craig Leach » Thu Jun 08, 2023 1:37 am
Hi Scott,
A gentalman I used to race with has a son that makes piercing jewelry. I don't understand why someone would intentionaly insert metal into thier
person. I spend a lot of time trying to remove the metal I accidently stick into mine. He uses a Unimat lathe/mill I'll bet you are familiar with
them. They may not be persision enough for what you do?
Re: Tool Time
Post by speedytinc » Thu Jun 08, 2023 8:24 am
Quality work. Looks professional.
Re: Tool Time
Post by Scott_Conger » Thu Jun 08, 2023 10:25 am
Craig
in my younger, snootier life, I'd have turned my nose up at a Unimat. I'm older/wiser and now have an appreciation for them and what they can accomplish...they're perfectly adequate for what I do, but having been an apprenticed watchmaker as my first adult job, I have an abundance of watchmaking equipment that can and is repurposed for carb parts. Otherwise, you'd be seeing Unimats in the background :D
John
thank you
Re: Tool Time
Post by Jerry VanOoteghem » Thu Jun 08, 2023 10:49 am
Speaking of Unimats, there is a fellow on an antique phonograph forum that I also haunt, who has converted one, (or maybe a Sherline?), to play cylinder phonograph records. He uses the Unimat(?) as the "base" and has added stepper motors and such, (that I don't understand), as well as an electronic pick-up to unable the playing of cylinder recordings.
Playing an appropriate tune.... https://www.youtube.com/watch?v=-iD_RUP2qhg
Re: Tool Time
Post by Scott_Conger » Sat Aug 05, 2023 9:33 pm
Just picked up this tap/die set...dates to pre 1912 and is a fractional set from 7/64 to 1/4 in 1/64 increments. Some real oddball stuff, and yet will see service in due time due to the kind of work I do. Was very pleased to get my mitts on it and for a very good price, too.
Re: Tool Time
Post by Rich Eagle » Sun Aug 06, 2023 11:13 am
Weren't those the greatest?
Thanks for showing it.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Tool Time
Post by BE_ZERO_BE » Sat Aug 12, 2023 1:41 pm
It's Italian !! :lol:
PBR - Perico Baroni & Raimondi 12" x 40" Lathe.
Made in Italy in 1966.
Respectfully Submitted,
Be_Zero_Be
Re: Tool Time
Post by Scott_Conger » Sat Aug 12, 2023 2:11 pm
very nice, Bob
what I wouldn't give for a larger heavier lathe... :?
Re: Tool Time
Post by Scott_Conger » Sat Jun 29, 2024 11:26 pm
Dies making carburetor gaskets:
Re: Tool Time
Post by Jerry VanOoteghem » Sun Jun 30, 2024 8:15 am
Beautiful work.
A friend of mine knows a guy who has made some very nice and fairly intricate gaskets using his wife's Cricket machine. My wife has one, but I'm probably not smart enough to program it to make gaskets, or much of anything else.
Last edited by Jerry VanOoteghem on Tue Jul 02, 2024 6:28 am, edited 1 time in total.
First Name: Adrian
Last Name: Whiteman
Re: Tool Time
Post by A Whiteman » Mon Jul 01, 2024 8:27 pm
My wife has one, but ....
she would be so mad I'd end up on the couch for a week if I used it? ;-) (like the time I used her good 'dress making' scissors ...)
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Tool Time
Post by Kevin Pharis » Mon Jul 01, 2024 10:42 pm
My dad scrounged one of these up a while back. It cut the paper gasket material surprisingly well… but the design software was miserable when it came to generating a mechanical drawing with specific dimensions and relations. Also found that the software couldn't accept any of the “typical” file formats either. Maybe there is a better software option out there that overcomes this setback…?
Re: Tool Time
Post by Scott_Conger » Wed Jul 03, 2024 2:35 pm
Best addition to a 9" lathe, ever
I have a full compliment of collets in 1/64" increments for my lathes but due to spindle size, you're limited to 1/2". I purchased this gawky looking thing which holds ER-32 collets and I can now go up to 3/4", or the size through my spindle. It will hold stock to .0005 TIR with no adjustment or confirmation or .0002" TIR with a gentle tap on the part. I could not be more pleased.
It requires fitting, so requires you to know lathe work and is not a drop-in tool. Mine had several quirky deficiencies which I was able to work past, considering that remediation of those deficiencies was easy, and the low price of the tool made fixable shortcomings as received, all but a certainty. There was nothing that could not be remedied and when done, the thing is highly accurate and repeatable from installation to installation. While nicely ground and capable of great precision, finding the precision in the tool is up to the purchaser and his/her ability to fit it correctly to the lathe. Purchase and shipping from UK came in (as I recall) under $100 which is an absolute bargain. I highly recommend it for small lathes with threaded spindles, for anyone who is capable of very close work.
Re: Tool Time
Post by Scott_Conger » Sun Jul 28, 2024 9:48 pm
The correct tools to set fuel level in Stromberg and Zenith brass carbs without altering the carbs by drilling holes or otherwise defacing them
While brass carbs frequently have odd-ball or obsolete threads in their construction, the 2nd pictured tool required fabricating the missing knurled packing nut and that was one of the zaniest threads I've ever come across and took no small amount of doing to make the nut to match the thread on the casting. I think it came out well.
First Name: craig
Last Name: leach
Re: Tool Time
Post by Craig Leach » Wed Jul 31, 2024 11:41 pm
I noticed that homemade tools where mentioned @ one point. Anyone seen one of these it's a homemade Gingery lathe. David J. Gingery
published a series of books on homemade tools starting with a primitive forge & casting machine parts. Then making a lathe, shaper, mill
& other tools. I picked this up with the castings already done & mostly finished. Just because it's cool & I've only seen one completed. now
I have more lathes than I have room for so if anyone is interested??? I would part with it pretty cheap?
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Re: Tool Time
Post by Ed Fuller » Fri Aug 02, 2024 7:56 pm
Scott,
Those carburetor tools are really neat. Are the period originals or something you made?
Craig,
I’ve read some of David Gingery’s books about making all of your own shop tools starting with casting parts and building the lathe. Then, using the lathe to create all of the other machines. That’s really neat to actually see one of the completed lathes! If I were closer I’d be seriously interested !
Re: Tool Time
Post by Scott_Conger » Fri Aug 02, 2024 8:53 pm
Ed
period tools
very hard to find
Bryant
First Name: Bryant
Last Name: Shafer
Re: Tool Time
Post by Bryant » Sun Aug 11, 2024 1:47 pm
This hand held sand blaster is magical. I just finished up all my wheel felloes and I love it. About $56 new on T bay. I just screen some play sand thru some window screen into a bucket and blast away. Makes pretty good cheap media that Iam not worried about recovering.
Bryant
Bill Dizer
First Name: Bill
Last Name: Dizer
Board Member Since: 2014
Re: Tool Time
Post by Bill Dizer » Sun Aug 11, 2024 6:41 pm
Please be sure to wear a good respirator when sandblasting using any media, but especially silica sand. When sand is used, it will fracture into glass like shards of dust that when inhaled do permanent lung damage and can kill you. The glass particles will cut your lungs, and cannot be coughed up or removed, and continue to do damage! A dust mask isn’t enough, use a good fitting painters type mask. I wear one always when blasting regardless of the media. I usually use the black slag type but it is very aggressive.
Bryant
First Name: Bryant
Last Name: Shafer
Re: Tool Time
Post by Bryant » Sun Aug 11, 2024 9:17 pm
Good advice. I use all necessary PPE. I also have two 4’ shop fans at my back to blow everything away from me. When blasting it’s also good practice to angle the media stream so it deflects away from you and not back at you.
Bryant
First Name: Austin
Last Name: Farmer
Re: Tool Time
Post by 1925 Touring » Wed Aug 14, 2024 10:23 pm
An old delta unisaw i repainted at work. Heavy as sam hill and would probably survive the blast of an atomic bomb.
I cleaned and degreased the dirt and grime off and sprayed a coat of grey paint on. First time airbrushing.
Seems to be oroginal except for the new paint. The signage on it is in good shape or the age. It was saved from an old factory by my boss's dad years ago.
Bryant
First Name: Bryant
Last Name: Shafer
Re: Tool Time
Post by Bryant » Thu Aug 15, 2024 6:17 pm
Nice work! Looks like a great time tested built to last machine.
Bryant
JohnM
Last Name: Michaelree
Board Member Since: 2010
Re: Tool Time
Post by JohnM » Thu Aug 15, 2024 10:01 pm
I probably used one just like it in my highschool shop class fifty years ago. No, that can't be right. :roll:
Duey_C
First Name: Duane
Last Name: Cooley
Re: Tool Time
Post by Duey_C » Sat Aug 17, 2024 8:07 pm
I'm not keen on re-painted things anymore but I have to admit that looks really nice!
Nice saw!
First Name: Adrian
Last Name: Whiteman
Re: Tool Time
Post by A Whiteman » Mon Aug 19, 2024 4:52 pm
Well, sometimes refinishing can look good:
First Name: Adrian
Last Name: Whiteman
Re: Tool Time
Post by A Whiteman » Mon Aug 19, 2024 4:56 pm
Bryant
First Name: Bryant
Last Name: Shafer
Re: Tool Time
Post by Bryant » Fri Jul 11, 2025 11:14 pm
What is it?
Works like a slide hammer
My guess is for prying and pulling nails
Bryant
First Name: craig
Last Name: leach
Re: Tool Time
Post by Craig Leach » Sat Jul 12, 2025 1:46 am
That would be correct & still made today as I understand.
Re: Tool Time
Post by Jerry VanOoteghem » Mon Jul 14, 2025 12:15 pm
Yes, a nail puller.
If you use it, be CERTAIN that when you grip the lower portion, just above the "foot", that none of your hand laps over the small ridge above the handhold. It's one of those mistakes that nobody makes twice!
Bryant
First Name: Bryant
Last Name: Shafer
Re: Tool Time
Post by Bryant » Mon Jul 21, 2025 7:38 am
Picked up this little voltage meter. Triplett model 310. In our current digital world I long for the analog. Watching the needle fluctuate is very satisfying.
Not sure how old it is. Trying to pick up its unique batteries now then we will see if it comes alive.
Bryant
Re: Tool Time
Post by TXGOAT2 » Mon Jul 21, 2025 1:03 pm
I think the meter will perform all functions except the ohm meter function without any battery.
First Name: Adrian
Last Name: Whiteman
Re: Tool Time
Post by A Whiteman » Wed Jul 23, 2025 8:39 pm
Ha ha - well put
Re: Tool Time
Post by Scott_Conger » Wed Sep 24, 2025 7:46 pm
In a past life...back when I though someone would buy this sort of stuff
Very small tools - OF jet manufacture:
VanEpsFan1914
First Name: Charles
Last Name: Foyle
* REQUIRED* Type and Year of Model Ts owned: My Corolla doesn't count.
Re: Tool Time
Post by VanEpsFan1914 » Mon Sep 29, 2025 2:55 pm
Rich P. Bingham wrote:
Fri Sep 09, 2022 8:46 pm
For those of us who only yearn at a distance for the massive tooling, I present this humble offering which actually makes a better hammer than a wrench, may all the monkeys who have busted knuckles with it Rest In Peace!
I have a smaller sibling of this wrench which I use for my antique DL-1 bicycles. They were designed in or around 1913 best as I can tell but mine are a '66 and a '72 (soon to be given to a friend.)
The hammer side is great for knocking out stuck cottered cranks and the wrench bits are necessary for Whitworth bolts if you can't find a Whitworth wrench anywhere.
Re: Tool Time
Post by Scott_Conger » Sun Oct 26, 2025 12:32 pm
I recently completed the purchase of a new, more powerful motor for my jet manufacturing lathe. Previously, it was powered by a typical high-speed, low power motor. At 1/15 HP it relied on very high speeds and tiny pully to generate the necessary torque to run various accessories.
Bodine motors and controllers are probably the Duesenberg of motors and after finding a NOS 1/8 HP motor two years ago, I finally found the mating controller in excellent shape. Since it is cast iron, including the base, his motor is the same size/weight of a motor twice its HP rating and though is relatively low in HP, it has huge torque throughout its entire speed range, which is what I need. This combination sells new for around $850 but with patience was assembled via eBay for right at $200.
It is now hooked up and is a beast - I could not be more pleased. If you are a watchmaker or clockmaker or have any kind of instrument lathe, you will do yourself a favor if you spend the time to invest in such a setup.
Since Levin Lathe company uses Bodine motors and controllers (and I have had the good fortune to use them), it was something I'd wanted for quite a long time
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Tool Time
Post by BE_ZERO_BE » Sun Oct 26, 2025 6:47 pm
Scott,
Great setup - Nice Lathe.
However,
It does look a bit "Rube Goldberg" :D :lol: :shock:
Be_Zero_Be
Re: Tool Time
Post by Scott_Conger » Sun Oct 26, 2025 6:56 pm
Bob, it would be silly of me to try to deny what is obviously true ;)
Conversely, it is a thing of beauty when under power - even Dr. Frankenstein was pleased with his creation, if not just a bit fearful of it :lol:
Re: Tool Time
Post by Scott_Conger » Thu Nov 06, 2025 2:38 pm
project had too narrow of an interest to take up space - removed
ironhorse
First Name: G.R.
Last Name: Cheshire
Re: Tool Time
Post by ironhorse » Thu Nov 13, 2025 3:39 pm
My new portable Paint booth. I new that army tent technology would come in handy one day!
Bryant
First Name: Bryant
Last Name: Shafer
Re: Tool Time
Post by Bryant » Fri Nov 14, 2025 12:31 pm
Looks like a bounce house! where's the slide at? LOL :lol:
I love it and where can i get one??
Bryant
ironhorse
First Name: G.R.
Last Name: Cheshire
Re: Tool Time
Post by ironhorse » Fri Nov 14, 2025 1:40 pm
Ebay or Vevor.com. that one was shipped to my door in 2 days for under $600
23 ft x 13 ft x 8 ft aprox will handle anything I need to paint easy to set up but putting it away you will need help
Ebay link https://www.ebay.com/itm/256870984197?_ ... 26.m162918
First Name: craig
Last Name: leach
Re: Tool Time
Post by Craig Leach » Fri Nov 14, 2025 8:12 pm
My brother is a professional painter he has one bigger than that & loves it & he does pretty good size cars & trucks in his. Said the air &
filtration system is great! With his gas powered generator he can go anywhere & paint.
Re: Tool Time
Post by Scott_Conger » Tue Nov 18, 2025 8:39 pm
Posting this to give someone an idea for fixturing things...
Teflon tape (.022 thk with PSA)
Inexpensive fixture track typically used by woodworkers, inlaid flush on a bench or other surface (Rockler)
Double-stick tape (3M)
I needed to be able to move this heavy motor back and forth behind the lathe to accept any number of locations supporting multiple possible attachments and yet still be able to sock it down tightly to keep tension on belt(s). I used the fixture track rather than mill out the aluminum baseplate, then applied Teflon tape to the feet of the HEAVY motor. Finally, before committing the track to a permanent position, the two tracks were laid in place using double sticky tape.
The whole thing is rock solid when tightened down and when loosened, the motor glides over the track almost effortlessly as if on ice. Simply snug down the nuts on the T Bolts and everything is socked down again. I may not even screw the track down, it's that positive of a locator...we'll see...
Anyone who has done much machining, knows about fixturing and I thought I'd share an unexpectedly resounding success with others with the hope to inspire the use of some non-traditional methods or materials.
Bryant
First Name: Bryant
Last Name: Shafer
Re: Tool Time
Post by Bryant » Wed Dec 03, 2025 4:30 pm
picked up this cast iron tape dispenser. Iam thinking it was made so heavy it wouldn’t walk off! Must weigh 10 pounds.
Labeled Texcal Tape
Bryant
JohnM
Re: Tool Time
Post by JohnM » Wed Dec 03, 2025 6:53 pm
You can hold with one hand what you want to tape, and dispense the tape with the other hand without dragging the dispenser across the table. ;)
Re: Tool Time
Post by Scott_Conger » Wed Dec 17, 2025 1:14 pm
I love the obsolescent and unloved, but this little gizmo is especially as sexy as can be...
A tool which has all but disappeared from shops save for a few old-timers, but is just as clever and handy as all get out. It is a GEOMETRIC die head. They can be had from "reasonable" to outrageous in price and in varying sizes. This one works very well on 9" or 10" lathes.
Once snapped "closed" the chasers close down to working size and apply threads to your work and once you've reached the length of thread you want on your part, the tool "pops" open which withdraws the chasers from the work and then the entire thing can be withdrawn without having to unscrew it as with a normal die. It is a very handy thing which works well either in a turret or in a tailstock which is allowed to slide along the ways.
The main benefit is that there are many teeth as opposed to a standard die which has only 2-3 teeth and due to that, if not very carefully applied a die will lead to drunken threads over a long distance. With this tool you can apply a very fine thread perfectly straight over a long length (think "spray needles") and the threads will be absolutely perfect. Additionally, the depth of the chasers can be fine tuned to give a slightly smaller or larger thread than standard which allows for the creation of custom parts to fit their worn-out counterpart more closely.
Am very pleased to now own one - and like all good tools, now requires a constant input of various chasers in order to do different threads - the best tools for an addict are tools which necessitate the purchase of YET MORE TOOLS! :lol:
1/1/26 Edit: for anyone curious as to what this does or how it works, the following is a very short and informative video of one in action: https://www.youtube.com/watch?v=JSMWLpx4rS4
BillWitmer
First Name: Bill
Last Name: Witmer
* REQUIRED* Type and Year of Model Ts owned: 1907 Model N,1914 Runabout
Re: Tool Time
Post by BillWitmer » Sat Dec 20, 2025 5:35 am
In my machine shop days we used these small geometric die heads on Hardinge automatic lathes. They were quite expensive when purchased new. Extremely accurate tolerance wise even after long production runs. Nice purchase!
Re: Tool Time
Post by Scott_Conger » Wed Feb 25, 2026 7:50 pm
Something you can only get away with in a one man shop :D
Way more fun than storing drills away in a HUOT drill index...Some shop ephemera from the 1920's:
With no drills in it, it weighs a couple pounds - a far more satisfying thing than standard plastic or sheet metal stands
The marginal lighting doesn't do justice to the very busy decorative embossing :)
And another one:
First Name: Dallas
Last Name: Landers
Re: Tool Time
Post by Dallas Landers » Tue Mar 03, 2026 9:08 am
Very nice!
Re: Tool Time
Post by Scott_Conger » Tue Mar 03, 2026 9:21 pm
glad you like them Dallas
they're just a little off-beat and unusual, and I doubt that many people have seen these or similar items so I thought I'd share. When I lived in FL I would never have dreamt of using them with all the humidity but now in WY, there is no reason to store drills away. For me, it's a peek into the past...how things were vs how they are now. My shop/barn is my refuge from the real world.
Re: Tool Time
Post by Jerry VanOoteghem » Wed Mar 04, 2026 3:53 pm
Real collectors collect collections! Drill indexes are just one of my collections. Here's a few interesting examples that I really didn't know existed until maybe a year ago.
Re: Tool Time
Post by Jerry VanOoteghem » Wed Mar 04, 2026 3:58 pm
A larger picture of the "display" area. The lathe is a W.F. & John Barnes "velocipede" lathe. Pedal powered. I tried it out a few times, but I'm afraid the break the cast iron seat under my unusual heft. :oops:
Re: Tool Time
Post by Jerry VanOoteghem » Wed Mar 04, 2026 4:01 pm
Here's more drill related stuff. A Union Twist Drill cabinet, an Oliver of Adrian drill pointer, and a wooden drill, (totally made of wood, but 100% the same manufacturing as its all-steel cousins. An advertising piece.)
Re: Tool Time
Post by Jerry VanOoteghem » Wed Mar 04, 2026 4:03 pm
And last, for now, some friction joint calipers...
Re: Tool Time
Post by Scott_Conger » Wed Mar 04, 2026 6:36 pm
Bravo!!
Wyoming approved!
Re: Tool Time
Post by Jerry VanOoteghem » Wed Mar 04, 2026 6:42 pm
Bravo!!
Wyoming approved!
It doesn't get much better than that! :)
First Name: Dallas
Last Name: Landers
Re: Tool Time
Post by Dallas Landers » Thu Mar 05, 2026 9:04 am
Wow! I have many old tools. Most are carpentry as thats is what I do. I have posted my Rockford economy lathe before and love doing projects with it. The open belts scare most but it keeps them back. Very impressive gentlemen.
