Yet another puzzle
Dan Haynes
Last Name: Haynes
Re: Yet another puzzle
Post by Dan Haynes » Mon Feb 20, 2023 9:14 pm
Herb's 5:39 post is an International
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Mon Feb 20, 2023 9:16 pm
Oops, both Herb's posts are at 5:39. The top one is the International.
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Tue Feb 21, 2023 7:05 pm
Herb's second vehicle appears to be an International Auto-Buggy - as opposed to Auto Wagons that have the stubby hood. They could be had with one, two or three seats.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Thu Feb 23, 2023 11:43 am
Maybe an easy one ? Unusual to have a photo of a car without any people in the pucture. Pretty setting !
Get a horse !
Post by Jerry VanOoteghem » Thu Feb 23, 2023 12:23 pm
Oldsmobile Model T? 1905/1906?
Post by Rich Eagle » Thu Feb 23, 2023 3:49 pm
It is a one cylinder Cadillac.
Post by Jerry VanOoteghem » Thu Feb 23, 2023 4:22 pm
With a French front? I do see by the frame/chassis how it's a Cadillac however.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Feb 24, 2023 11:02 am
You fellers amaze me !! I'm a very poor researcher. It seems the Olds T was still a curved dash "merry" Oldsmobile. I found one image of a Model N that appears to have a hood / front end like the one in the old photo, but I can't see details of the chassis. Coachwork on the Caddy Rich posted is quite different, but that doesn't mean much. The chassis is very much the same ! Thanks for "playing", I'm learning a lot from these puzzles !
Get a horse !
Post by Jerry VanOoteghem » Fri Feb 24, 2023 12:11 pm
Rich B.,
This is an Olds Model T.
The Curved Dash Oldsmobiles were models, R (1901 - 1903), 6C (1904), & B (1905 - 1906).
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Feb 24, 2023 2:23 pm
Jerry, I only know the misinformation I found on the interweb ! :lol: That's a good side view, the front end and front seat look more like the old photo. Is the jury still out ?
Get a horse !
Post by Jerry VanOoteghem » Fri Feb 24, 2023 2:37 pm
I'm sure Rich Eagle is correct in that it's a Cadillac. I probably just don't know enough about Cadillacs, (and lots of other stuff too :) ), to know of a French Front example.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Feb 24, 2023 3:19 pm
What's visible of the Olds in the photo you posted sure doesn't look like the Cadillac chassis. I believe Rich nailed it - again ! :lol:
Get a horse !
Post by Rich Eagle » Fri Feb 24, 2023 3:25 pm
I don't claim to be a Cadillac expert or that of any other make. All I can do is offer what I think I see in these photos. I knew that the photo I posted was not the same body style and might raise questions. This 1902-1908 Cadillac Single Cylinder booklet shows that there were 9 different Models of Cadillac. Most were open runabouts or Touring cars. The first models look almost exactly like a 1903 Model A Ford. Then there was a box front and later variations of a front similar to the Madel C Ford. I haven't ever seen a Frenc Front Cadillac and don't think I see one in Rich's photo.
I have been around a few of them and noticed the stepped frame near the crank hole and the associated spring mounts and radius rods. Also, the step plate.
I was surprised when I saw my first hood on a single-cylinder Olds too.
Post by Rich Eagle » Fri Feb 24, 2023 3:42 pm
This is what I believe we are seeing behind those Foreign Headlights. Left is a Model E and Right is a model F. Both are 1905 I believe.
The door to the tanks under the hood and wing nuts, the rail above the dash and the lower apron and radiator can be seen. I believe there are the same.
Post by Rich Eagle » Fri Feb 24, 2023 3:57 pm
This 1905 Model F has a body that is much the same.
Post by Rich Eagle » Fri Feb 24, 2023 4:29 pm
This might be a good place to tell what little I know about those French Front Oldsmobiles. This one was on the St. George 1&2 Tour in about 1985. It was a rear entrance car as were several including some Cadillacs and Fords.
A similar hood and rail as the Cad.
One key difference in Olds cars is their full-length leaf spring units on either side of the car.
The brass lever is the spark advance which covers the crank hole when advanced to prevent back firing.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Feb 24, 2023 4:44 pm
Rich, thank you much for posting those photos. Delightful to see ! And very instructive vis-a-vis the "puzzle". I'm amused to learn of the Oldsmobile's full length leaf springs. Some of Studebaker's high-end horse-drawn light vehicles used that design in the same era. It would be interesting to know for sure whose idea it was !
Get a horse !
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Fri Feb 24, 2023 9:48 pm
Here's one for ya...
Post by Rich Eagle » Sat Feb 25, 2023 11:25 am
That's a good one. I don't recognize it, but it looks like a steam car. I'll do some digging. I hope someone knows.
Post by TXGOAT2 » Sat Feb 25, 2023 12:01 pm
I can't see how the full length springs would do much for ride quality, but they would provide a very strong and flexible chassis, which would be good with a mid-engined car. That wouldn't explain their use on a horse drawn vehicle, unless it had a very heavy body mounted in the middle of a long wheelbase running gear.
Post by Jerry VanOoteghem » Sat Feb 25, 2023 3:23 pm
Rich E.,
I'm pleased that I was wrong about the Cadillac! It sparked a great conversation and some interesting pictures. Thank you sir!
Post by Rich Eagle » Sat Feb 25, 2023 4:36 pm
Thanks Jerry, I learn a lot from these conversations and the searches for photos. It's a great way to spend time. After collecting stuff for years, it's fun to go back at look at things and share the info with others who may enjoy it too. Here are some cuts from that instruction book.
The illustration efforts of 100 years ago plus are so wonderful.
I'm happy you are finding time to guess along too. What could be more fun?
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Fri Mar 03, 2023 2:22 pm
Sent to Libertyville Iowa in 1910.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Mar 03, 2023 5:12 pm
1903-04 Knox on the postcard sent to Libertyville.
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Sun Mar 05, 2023 9:23 pm
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Mon Mar 27, 2023 4:34 pm
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Mon Mar 27, 2023 10:09 pm
ironhorse
First Name: G.R.
Last Name: Cheshire
Post by ironhorse » Wed Mar 29, 2023 4:37 pm
While cleaning out one of the rooms in the house I found these
The one on the right was my Stepfathers first car (that's him beside it)
The one on the left was a wreck my Stepfather was involved in, It was big news in Bradenton Fl 4 March 1954.
Post by Rich Eagle » Wed Mar 29, 2023 4:52 pm
It's fun to look back into those days, isn't it?
Thanks for posting those.
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Wed Apr 19, 2023 9:24 pm
Gotcha now.
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Thu Apr 20, 2023 7:33 am
French Renault taxicab, one of the famous ' taxis de la Marne" who were commandeered to transport troops to the front in 1914. (French postage stamp in the right upper corner seems to heave a 1915 date stamp, hard to make out for sure)
Leo van Stirum, Netherlands
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Apr 21, 2023 3:11 pm
New York license. Make, please ?
Get a horse !
Post by Rich Eagle » Sat Apr 22, 2023 11:52 am
It looks like a 1910 Buick Model 17 Touring to me. The NY plate would be likely a 1910 (white on black) or perhaps a 1911 (white on maroon).
The photo makes the radiator look a bit wider.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sat Apr 22, 2023 11:57 am
Thanks Rich !!
Get a horse !
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Tue Jul 29, 2025 8:50 pm
Watching a news briefing on the YouTube
I saw they found this old relic in lake lure after hurricane Helene. The vehicle was found when they dropped the lake depth in efforts to clean up debris. They said it was most likely abandoned there before the lake was even there. The news anchor said it was a model T. Iam not convinced. I see leaf springs. So here is yet another puzzle. good luck!
Bryant
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Tue Jul 29, 2025 8:54 pm
