connecting rod size
John bevardos
Topic author - Posts: 155
- Last Name: bevardos
- * REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
connecting rod size
Hi guys ,
my basic math has left me ----- I have a crank that was ground .005 undersize and my connecting rod choices are either std or .010.
Should I use the std size rods and take shims away or should I scrape the .010 down? Btw--its to replace existing rods in the engine already .
Thank you
John
Thank you
John
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Adam
- First Name: Adam
- Last Name: Doleshal
Re: connecting rod size
Scrape the .010” rods is your best bet for a tight clearance.
Standards will be your easiest option, but will end up with wider side clearances. If you go with standards and remove shims, you will have your target clearance top and bottom, but .005” over that on the sides.
tman1913
- First Name: Mike
- Last Name: Bender
- * REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Why not have a set of rods poured and cut to your size. They are a number of companies that can provide you that service for the same price as a standard or .010" under rod.
Mike gives good advice. This is exactly what I did and am happy I did. Don't fool with trying to tell THEM what you need by calculating the size...just measure your journals, and if they are round and straight, tell them the size and they will bore them to be the correct fit from the get-go. Like Mike says, there are several folks to go to and if you'd like a recommendation, email me.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
John- I replied to your other thread regarding rods and never heard from you.
Dan
Dan
John bevardos
Guys, thank you for all the replies. Dan, PM sent. Thank you, John
Gene_French
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
John:
if you start with the minus .010 rods (1.240" diameter ) you can scrape or bore to the 1.245" diameter needed … can make a smaller bore bigger but not so easy to make a too big bore smaller … always an optimist ...Gene French
