band material?
First Name: craig
Last Name: leach
band material?
Post by Craig Leach » Sun Feb 09, 2020 12:06 pm
Found this in some T parts I bought along time ago. Is this band material its 1.71 wide and .169 thick. Thanks. Craig
IMG_1403 (1).JPG (20.48 KiB) Viewed 4494 times
Re: band material?
Post by DanTreace » Sun Feb 09, 2020 12:26 pm
Too wide for narrow bands, too narrow for wide band ;)
First Name: craig
Last Name: leach
Re: band material?
Post by Craig Leach » Sun Feb 09, 2020 1:13 pm
Hi Dan,
Yes it is narrower than the drum but is the same width as the wide band I have. Anyone have an idea what it is if not band material? thanks.
jiminbartow
Last Name: Patrick
Re: band material?
Post by jiminbartow » Sun Feb 09, 2020 1:57 pm
I don’t think it is Model T band material. Looks more like antique oil lamp wick material. Jim Patrick
Re: band material?
Post by Steve Jelf » Sun Feb 09, 2020 2:53 pm
Gas tank padding?
Re: band material?
Post by Wayne Sheldon » Sun Feb 09, 2020 5:46 pm
Looks to me like too dense of a weave to be lamp wicks? Looks a bit thin to be T band material? Such woven belting was used for many hundreds of uses! It may have been for use on some non-Ford open transmission? Likely not. Gasoline tank padding? Likely. Similar belting used to be available in bulk in dozens of common sizes, for hundreds of uses. That close in size? I would be surprised if it wasn't used as a "make do" for a T's bands a few times. I wouldn't recommend it for that now however.
Duey_C
First Name: Duane
Last Name: Cooley
Re: band material?
Post by Duey_C » Sun Feb 09, 2020 6:38 pm
BIG lamp if so... ;)
Last Name: Seth
Re: band material?
Post by perry kete » Sun Feb 09, 2020 6:42 pm
I thought this was band material...
Re: band material?
Post by Wayne Sheldon » Sun Feb 09, 2020 11:19 pm
Is that Sousa?
First Name: craig
Last Name: leach
Re: band material?
Post by Craig Leach » Tue Feb 11, 2020 8:13 pm
Thanks everyone I think I will put it away for now. I'll save it for for an emergency. You never know there may be something to the zombie apalypse. ;)
