Valve stems for 1921.
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Thu Feb 20, 2020 7:58 pm
What brand and number Valve Stems were used in 1921?
Re: Valve stems for 1921.
Post by Steve Jelf » Thu Feb 20, 2020 10:12 pm
Ford used Shrader #777, but other sizes will work and are easier to find.
http://dauntlessgeezer.com/DG110.html
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Fri Feb 21, 2020 1:37 am
Thank you for the information.
Post by Allan » Fri Feb 21, 2020 10:23 pm
The other commonly found one is 1/4" different length, Shraeder no 888. Most others are larger in diameter.
